Home > Puma (Tdci) > TDCi Reliability and Longevity
Gwynne_90
Hi there.
I'm looking at buying a 2007 TDCi with 76,000 miles on the clock. It has a perfect main dealer service history with an annual service carried out exactly every 12 months which is 10,000 to 12,000 miles. It starts and runs well and is in good overall condition.
My concern is the mileage as there aren't many Defenders with the Puma engine around (that I can see) with 100,000 plus mileage and I'm looking for something that I can use and keep up to say 120,000 miles - which will be another 5-8 years.
Does anyone have any experience or advice to share? How good is the Puma engine long term and any major issues likely?.
Post #318035 22nd Mar 2014 8:47am
K9F
It's a Ford Tranny engine....therein lies your answer. It should go on and on. Noworries 4X4 on here covers phenominal mileage in his and yes he has had issues recently in France but considering the mileage he covers two engine failures he still rates them.
http://www.defender2.net/forum/post294861.html#294861
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #318036 22nd Mar 2014 8:50am
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Don't know about up north but here down south there there are a great amount of Pumas with over 200 000km on the clock.
Post #318043 22nd Mar 2014 9:15am
My '07 has 139k miles on the clock. It's just about 'run in' now.
Post #318045 22nd Mar 2014 9:36am
jimbob7
As others have said,it's no less reliable than any other engine really,I will stand corrected,but I believe the earlier Pumas' have or had clutch issues,so may be worth a thorough check when you test drive it. Pov.spec,ftw. 2006, 110,TD5.
Post #318077 22nd Mar 2014 11:55am
Gwynne_90
Anyone know about the following service bulletin - was it mandatory to all 2007 TDcis?
Land Rover Service Bulletin SSM38792, 2.4 Puma Engine Knock Noise.
Title: 2.4 Puma Engine Knock Noise.
Type: LD - Defender - All Years - Special Service Messages - Engine
Name / Part No: SSM38792
Info Type: Service Bulletins
Version No: 1
Date Uploaded: 21 Jul 2008
Models: LD - Defender
Last Modified: 21-JUL-2008 09:44
Category: Engine
Symptom: 497000 Engine Noise
Content Issue: Heavy audible knocking heard on start up.
Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur.
Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used.
This condition will not occur on vehicles post assured Vin# 9A767162.
Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed.
Post #318093 22nd Mar 2014 1:07pm
110k on me then Blackwolf. Razz ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #318094 22nd Mar 2014 1:10pm
Gwynne_90 wrote:
Anyone know about the following service bulletin....
Yes!
Gwynne_90 wrote:
- was it mandatory...
No, only affected vehicles. It is not clear at this time what happens if you suffer this now, out of warranty. LR may consider contributing to the cost.
Check engine number or service history to find out if it's been done.
Post #318100 22nd Mar 2014 1:28pm
Yup, filling the tank twice a week at the moment! Big Cry
And I do mean filling, not just topping up. Big Cry
Post #318101 22nd Mar 2014 1:32pm
Ouch and on a 110 too. Shocked ____\We|Will|Win/___
Post #318111 22nd Mar 2014 2:04pm
martinfiattech
We have the 2.2 in our ducato and the 2.4 in the ldv convoy some die at 60,000 miles dodgy injector smashed piston, others get to 150,000 miles then the cam shaft carrier cracks a well known dura torque engine issue especially when hammered.
Theres always the timming chains but they rattle when cold and give plenty of warning.
We had one get to 456.000 miles in a mini bus it was a 2005 model ldv in the end the bottom end let go.
Shame as the owner needed it for a few more months until he retired !
These engines are all in vans given little respect always hammered, usually with little or no oil them.
I`am presently fighting with a 2011 parts van with a 2.2 unit with 110,000 miles behind it the engines fine but the recurrent maf / egr fault is getting annoying its looking like the ecu may be faulty due to the amount of water and corrosion in the loom and multy plugs
Post #318131 22nd Mar 2014 4:34pm
Cuthbert
Whenever I see the 'Ford' badge on a product I think "Value engineered - designed to a low cost and then redesigned to save further costs and then the supplier of every component has shaved even further costs out of each part".
Having once bought a Ford car I quickly realised why they would never ever compete with the premium brands. I was however impressed at how one part could fit a myriad of different vehicles in the Ford range.
'Mondeo Man' and 'White Van' man are their core customers and that's where they make their money. Just look at their attempts to move up-market with Volvo, Jaguar and Land Rover - don't think they ever got to grips with the requirements of those customers.
At least if my Defender engine implodes, explodes or just expires gently, there's usually a bloke in a rickety shed down by the canal who can transplant another unit.
Post #318180 22nd Mar 2014 8:18pm
Dieselhead
A mates 2009 is soon to hit 100k
No problems with the engine apart from 2 EGR valves & a MAF sensor
Thats that Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #318195 22nd Mar 2014 9:02pm
Toplink
[quote="Gwynne_90"]Anyone know about the following service bulletin - was it mandatory to all 2007 TDcis?
Version No: 1
Category: Engine
Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed.[/quote]
Just read this and looked at my VIN Big Cry Big Cry Big Cry and mine now knocks when cold stops after 2 miles. 84k on the clock and oil changed every 6k.
I think I will just drive it on and see what happens Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #318505 23rd Mar 2014 9:36pm
dgardel
Italy
may be the clutch if it knock at engine stop Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #318986 25th Mar 2014 2:43pm
