![]() | Home > Maintenance & Modifications > vent seals |
Hi Peterl,
Have a look at the link below.... http://www.landyzone.co.uk/lz/f7/defender-vent-seals-76647.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
the old series rubber seals are much better than the later foam ones,try them, you can get them from Dunsfold LR 2.4 90 XS
Thanks for that one Grocks ![]() I'll get some as back-up next time I'm over there. |
peterl Member Since: 08 Jan 2009 Location: Pembrokeshire Posts: 312 ![]() ![]() |
Thanks for this, ordered seals with Dunsfold this morning. Fun will start when fitting them tomorrow.
glad to of been a help 2.4 90 XS
Fitted and sealed inplace, water test in the morning.............
