![]() | Home > Maintenance & Modifications > Snow Cowl |
AlisterC Member Since: 25 Apr 2012 Location: Somerset Posts: 116 ![]() ![]() ![]() |
Entreq gets my vote
Expensive but really well made. I've had one on mine for 2 years now, and it looks as good as day one |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
The original ex-MOD one is excellent. To be fair though, it's not as if it's a piece of complicated machinery - I think all of the various versions do exactly the same job.
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
Basically, get one that doesn't break or crack when you stand on it. Any that do that job are best, but they all do the primary job just the same - prevent snow getting into the intake. 1998 110 300Tdi White Hard Top
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 247 ![]() ![]() |
Had the MOD jobbie and now have Mudstuff both work "Rafiki" 2007 110 STW - Rolling rebuild.
I was offered an entreq, beautifully made, but a lot of £ for a logo IMHO, I have a blanchards metal on and a mud stuff plastic one.
TBH the mudstuff one is strong enough to stand on and is plastic, worked fine in the arctic last year |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6666 ![]() ![]() ![]() |
Don't forget the IRB alloy one either
If you like the look off it I can understand fitting one but I clear most off the snow off my car before driving so I don't see the need fitting one.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Roel some people (myself included) fit for 'styling!'
Believe you don't!.... ![]() ![]() ![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Eh, no not really:
My toys: ![]() Click image to enlarge ![]() Click image to enlarge The 90 is road legal again so I don't use the trailer for events in The Netherlands anymore. It will end up in one color when I have my roll cage ready. I am test fitting it now regulary and make scratches on the body. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17779 ![]() ![]() ![]() |
It also of course does a great job keeping water out (both rain and spray) and as a result the interior steams up less.
It seemed to me a daft idea when LR put an upward-facing hopper at the heater intake! |
Egghead Member Since: 25 Nov 2012 Location: Surrey Posts: 256 ![]() ![]() ![]() |
I got one of an Ebay seller that's tough as nails but I also wanted the gloss finish (shiny black Chelsea Tractor) Suits the vehicle nicely and does exactly what it was designed for... keeps snow and water out.
I didn't think about the water. You got a point there. Roel
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
More use for water than snow in this part of the U.K, when i fitted mine there was an inch or so of water in the trunking as the drain valve had blocked with debris so when the heater was on it was drawing in moist air, just what you don,t need when trying to clear your windscreen ! 2005 Td5 90 XS
Steve |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
I fitted a entreq one to mine at some point i will pair up the other side. I find it excellant at keeping rain ouut and water when i have been playing which then used to spit up at the window lol 2004 TD5 Defender 90 xs station wagon
