![]() | Home > Puma (Tdci) > To de-cat or not? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2678 ![]() ![]() ![]() |
I have de-catted with a BAS remap and no issues at all, no extra noise, just a bit less heat in the cabin and turbo seems to spin up a little bit faster from standstill. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I,m pretty sure there has been a thread on here very recently about re-fitting cats as its now a part of the MOT to check for the presence of a cat on a vehicle originaly fitted with one. 2005 Td5 90 XS
Steve |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
He already knows that Lou ... Read the whole post
![]() Ian - Engine will run better without the cat, its not there to benefit the engine, but to 'strangle' it a bit to meet emission levels ![]() |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Leave it fitted
This is an 'emotive' subject for some that feel as though it is their sole aim to 'police' the catalyst issue. It is best left to personal choice and trawling through historical threads than opening up the same can of worms with the same individuals gum bumping and singing the same old boring tune.
Mind you without a catalytic convertor the gum bumping turbo would spin up quicker and the tune would sound a little throatier I think. ![]() Treat every day as if it is your last....one day you will be right!! |
Well said, you can stop bumping now!
![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Ian Mac Member Since: 16 Oct 2013 Location: Essex Posts: 53 ![]() ![]() |
Thanks All.
Would The car new a new rem app or will the current BAS remap be fine? Thanks Ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
Ask Pete [BAS], He'll have the definitive answer to that ....
![]() Click image to enlarge ![]() |
