Home > Maintenance & Modifications > LED lights on trailers?
BigWheels
Much has been written about LED exterior lights for Defenders.
Do the same rules for LED bulbs replacing filament ones apply to trailers as to vehicles?
I notice some trailers have outline LEDs in as many colours as Christmas trees! Are all colours legal for such use, especially blue? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #316809 17th Mar 2014 11:03pm
Same regulations such as E marking I'd imagine, as it is being used on the road. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #316815 17th Mar 2014 11:12pm
JWL
I haven't had the experience yet but, what happens when you hitch up a trailer with full led bulbs, I take it the indicators still work with a standard towing vehicle, is there enough load on the circuit to enable the trailer telltale on the dash? Just curious.
Post #316847 18th Mar 2014 1:13am
Romadog
the lights will work, but the warning lamp on the dash for the indicayors may not work due to low current draw. However if the lights fitted have a resistor fitted inside for each function then this wont be a problem.
Newer vehicles with canbus looms, have problems with the indicators flashing too quickly. This is similair to when the indicators flash more quickly due to a blown bulb on the circuit. Iuse a Brian James trailer at work which has just rear LED lamps. The indicators flash fast on my Ranger, but when tested on a Connect they flashed at normal speed.
Post #316931 18th Mar 2014 6:11pm
If you have RDX led lighting the relay works with an led light trailer but you won't get the dash lights as it simply can't detect it.
You'd need resistors on the indicators only for it to all work in sync.
Flash rate with a vehicle with incandescent regular lighting should be fine with led trailer lighting but again dash light could be an issue.
As the load of the lighting on the vehicle is pretty much stable the LED lighting flash rate should be about the same. ____\We|Will|Win/___
Post #316933 18th Mar 2014 6:17pm
I had a quick look on the mobilecentre site for some LEDs for my merlin , nice selection Thumbs Up
Post #316936 18th Mar 2014 6:25pm
JWL
Sorry if I sound like a Luddite but, apart from the supposed longer life of an led bulb(though I've only ever replaced one filament indicator bulb on my 12 year old Defender) and the lower current draw(I have got leds in the sidelights, never worry about leaving them on with the engine not running) I don't see much point in changing the indicators over due to the other issues that go with making them work.
Post #316941 18th Mar 2014 6:58pm
grafty99
I think that led indicators stand out much more in traffic than incandescent ones, my opinion anyway for what its worth Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #316942 18th Mar 2014 7:02pm
If you get the LED relay from RDX there is no issue involved at all with led indicators.
Edit*
And they are indeed brighter, especially brake lights. ____\We|Will|Win/___
Post #316954 18th Mar 2014 7:32pm
I agree with ^^
But if you tow trailers, caravans etc that don't have led indicators it may overload the led indicator relay. ?
Post #316967 18th Mar 2014 8:14pm
Steve - No it handles that too. Thumbs Up ____\We|Will|Win/___
Post #317003 18th Mar 2014 9:47pm
