![]() | Home > Maintenance & Modifications > Replacement headlight harness - Highly recommended |
| Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492
So an envelope arrived from China today with my £7 eBay harnesses, great just in time for the weekend. I had ordered four sets, using separate ones each side for me and StephenO.
My excitement was short lived though........ This was what turned up Click image to enlarge Awaiting a response now, will see what happens. 1994 Def 90 300tdi |
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265
Mine turned up this week also.
Here's a photo help you compare Click image to enlarge They look well made and although I ordered 2 I think I'll only use one. I'll swap the relays though. |
You can really go off people............
Had a good sounding response from the seller, hopefully be sorted out, just another few weeks no doubt. 2015 RRS Autobiography SDV6
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5816
Is everybody who recently have installed this upgraded loom from Landreiziger, Holland happy with the end result?
I also bought this loom, and the truck goes later this week to the dealer for some maintenance and other warranty work, and they also intend to install this loom then. I showed the Landreiziger loom to them earlier today, and they say that the only thing that needs to be done is to extend the permanent live cable, so that power can be taken directly from the battery. Tks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
Why do you want to extend to the battery if you have already a permanent live on the starter motor and altenator? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Mine went straight to the alternator
Hi Roel, mk1,
It was a bit of a rush rush discussion abt this loom at the dealer today amidst of talking about a bunch of other jobs they will have to do this wed-fri.... May well be that the battery connection was even brought up by myself, so wednesday I will mention the alternator and starter motor connections you mention here. Just one thing, I want to be able to turn at least the sidelights on without having the key in the contact, so hope that the live to the alternator indeed is a permanent live. I guess the starter motor live is not really permanent, only comes on with the key in/contact on, no? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
My sidelights can stay on without the key in the ignition
Still waiting on my harnesses, they were supposed to have been resent
So truck came back from the dealer friday with the "Landreiziger" headlights loom installed. They made one change, in order to be sure to have a good earth, they cut and extended the black earth wire, and connected it as in below picture, believe that is on top of the airco compressor.
Dealer mechanics commented that this loom indeed is a good solid piece of kit, and when I mentioned the price to them they were very surprised. (certainly as they are used to Swiss prices So I guess I will never have the use the spare light switch which I bought together with the loom from Landreiziger as a package deal. Goes in the spare parts storage. Eric Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Not only you DaveT who didn't get their harness. I ordered mine in January (and paid) and then when I complained in March the vendor said he would send a "replacement" harness. This arrived in a week. I had to wait as fleebay said the order was still within timescale as the vendor kept moving the delivery date.
Oddly the wiring only allows either the dip or full beam on at once. Whereas the standard set-up is that you can 'flash' while on dip and have all 210 watts showing. This is different but is it a bad thing? Merlin |
I am still waiting
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
should all work the same if triggers are taken from original wiring |
