Home > For Sale & Wanted > [For Sale] Mud Pod, Land Anchor, CB Aerial |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 856 |
I will have the mud pod please
16th Mar 2014 8:13pm |
blackbeltbob Member Since: 02 Jul 2007 Location: Troon Posts: 7 |
Excellent!
PM on its way! |
16th Mar 2014 8:46pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2724 |
maybe interested in the CB aerial. Where would it mount on a defender? can't think of any flat steel panels? did you have it fitted to a discovery then? Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
16th Mar 2014 10:23pm |
I had it mounted to the bulkhead behind the driver's seat so it was horizontal. I had great plans for a simple plate on the roof however I got great reception where I put it so never needed to
And it was the perfect length to fit in the 90. |
16th Mar 2014 11:27pm |
hmm ok, I'm home tomorrow (reunited with my 110) tomorrow so will have a look around for mounting points. You're welcome to sell if someone wants it before me, but i may get back to you.
Any chance you could give a rough estimate of diameter/max width of the base and length of the aerial so i can see how it would fit in various places? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
16th Mar 2014 11:56pm |
If you want a discreet mounting stick a sheet of steel on the underside of the roof behind the headlining. To make it really secure glue another magnetic base on the underside, just make sure you get the magnets the right way round, I've done this to secure a magnetic flashing beacon on previous Defenders over the years
17th Mar 2014 12:19am |
Morning
I've had a thought - not much use now I suppose - but I had a bulkhead removal bar so it probably stuck itself to that however the plate idea would still work there. It's 7 inches wide at the base and 42.5 inches long. Hope that helps. |
17th Mar 2014 7:55am |
Cheers guys ill have a look today at where it could go. Feel free to sell to someone else, I'll get back to you if I find somewhere... Cheers, David
17th Mar 2014 12:51pm |
