Home > Maintenance & Modifications > Looking far a strong above door interior handle
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi
Some passengers are complaining about the absence of an interior above door handle.
Anyone fitted such a door handle?
Information apriciated as I planned to remove all interior due to sounddeadening / isolation fitment and like to do this mod in the same time.
Q.
Post #316565 17th Mar 2014 9:20am
max peck
United Arab Emirates 2009 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Hi ,
I Have MUD-STuff grab handles. They work fine.
Post #316572 17th Mar 2014 9:56am
Naks
Max, how did you fit them? --
Post #316579 17th Mar 2014 10:48am
max peck
Fitted perhaps not the optimum way. The headlining and door seal get in the way.
I took the headlining off and used one of the holes for the existing headliner fastner and drilled a new hole
into the gutter for the other fixture.
I fitted with a bolt and some wide washers down through the gutter. Then put thr headlining
back on followed bu the handle plus washer plus nut.luckily the bolt head didnt spin and I could
tighten the nuts.
not great cosmetically but helps herself to climb in.
Post #316607 17th Mar 2014 1:51pm
pepekleinhans
South Africa
I used one from a Fiat Uno, I had to cut the roof lining little bit so I could get the handle flush with the roof frame, drill 2 holes and screw it in, works perfectly, the wife is very happy now.
Pepe 2005 Discovery 3 HSE
2007 2.4 Puma Defender
1976 series 3 with Ford V6 engine
Post #323929 15th Apr 2014 6:44pm
