Home > In Car Electronics > Rear power supply for 2 work lights?
SailingTom
Hi there on my soft top ive fitted an LED rear work light using the 2 blank power terminal under the internal light guard (2011 puma 90)
On my next one im thinking of fitting 2 rear lights (light in question is an 18w 6 LED type). As its a low power LED type will I get away using 2 off that supply or is there another redundant power supply I can used? So would it have to work off a rear wiper power supply or heated screen?
Cheers Tom Defender puma dormobile camper
Post #315984 14th Mar 2014 6:44pm
I run 2 LED worklights off the redundant HRW feed on my DC and they are very low current. The 12V feed should be fine. I actually run an LED striplight of it which will draw at least as much juice as the worklights.
Post #315996 14th Mar 2014 7:21pm
SailingTom
Thanks. Ill run them off that supply instead next time then, most only fit one but seems ill get away with it then.
Cheers Tom Thumbs Up Defender puma dormobile camper
Post #315999 14th Mar 2014 7:24pm
