Home > Puma (Tdci) > Clutch stuck in and will not release
Naks
Hi guys,
I got to work this morning and while reversing into my parking bay, the clutch would not release.
I had to stall the landy and then push it back into the parking bay.
The clutch is stuck in and will not release, what now? Big Cry --
Post #315188 11th Mar 2014 8:32am
theorangebandit
Have you checjed the clutch fluid? If the fluids dropped there'll be no pressure to return the pedal. Other sinsiter problems may be the the boot on the slave has popped off. So you may find a puddle under the bell housing after work.
Post #315193 11th Mar 2014 9:00am
Naks
Yep, will go check the clutch fluid.
I haven't noticed any leaks in the garage.. Confused --
Post #315197 11th Mar 2014 9:25am
If it was in use and working up to that point I would suspect a loss of fluid for some reason. Does the pedal 'feel' normal?
If the vehicle had stood for a while the driven plate can stick to the flywheel giving the same result, but this is very unlikely if it was working as you drove to work.
Post #315212 11th Mar 2014 10:32am
Naks
It's been 2 hours since I got to work, and I went to check the clutch fluid level.
I stuck my finger in the reservoir and touched liquid at around 5-6cm down from, and it was black-ish. Is this normal or not?
Also, I fiddled with the clutch pedal and it popped back up. I then started the car and pumped the pedal for about 5min, and it felt normal - it didn't soften or harden.
No signs of anything leaking underneath either. --
Post #315214 11th Mar 2014 10:40am
When you say "the clutch was stuck in" do you mean "in", ie pedal up, clutch engaged and won't disengage, or do you mean "out", ie pedal down, clutch disengaged and won't engage.
The terms "in" and "out" are very often used incorrectly, and I wonder if this has happened here since you now say "the pedal popped back up".
A clutch fault causing the clutch to stick "in", ie engaged, will lead to a completely different diagnosis to a clutch fault causing it to be stuck "out", ie disengaged.
Post #315219 11th Mar 2014 11:18am
Naks
I meant the above.
As in the clutch wouldn't engage and I had to stall the car to avoid crashing into stuff Sad --
Post #315220 11th Mar 2014 11:42am
theorangebandit
That clutch fluid should be level with the top of the tube you put your finger in. And it also shouldnt be black. It sounds like your repair is simply to bleed the clutch fluid. A nice easy job the wife can help you with too
Post #315223 11th Mar 2014 12:09pm
Naks
thanks, but will leave it to the indie workshop.
is clutch fluid the same a brake fluid, i.e., Dot4? --
Post #315225 11th Mar 2014 12:18pm
theorangebandit
Yes both are dot 4.
Post #315227 11th Mar 2014 12:35pm
Naks wrote:
I meant the above.
Still confused!
If the clutch "wouldn't engage" the engine is disconnected from the gearbox and you won't crash into stuff.
If you "had to stall the car to avoid crashing into stuff" then you're saying the clutch wouldn't disengage.
If the latter, it brings us back to fluid levels, cylinder seals or operating linkages as the likely culprits.
Post #315242 11th Mar 2014 2:17pm
Naks
Just to update you guys:
The indie bled and refilled the system and then took it for a 40km drive. Upon return, the clutch fluid was below fill level and there were signs of clutch fluid leaking from the gearbox.
That meant that the gearbox has to come out for an inspection of the slave cylinder, which is probably the culprit.
So I have to spend a few days driving a VW Polo Big Cry --
Post #316437 16th Mar 2014 5:29pm
roel
I am not that familiar with the Puma but is the slave cylinder not attached on the outside? So you can just take the slave cylinder off for inspection????? Roel
2003 90 Td5 (2009-now)
Post #316443 16th Mar 2014 6:33pm
Naks
nope, the Ford design is such that the slave cylinder is inside the bellhousing:
Quote:
Clutch Controls - 2.4L Duratorq-TDCi HPCR (103kW/140PS) - Puma -
Clutch Slave Cylinder
Removal and Installation
Removal
1. WARNING: Do not work on or under a vehicle
supported only by a jack. Always support the vehicle on safety
stands.
Raise and support the vehicle.
2. Disconnect the battery ground cable.
For additional information, refer to: Battery Disconnect and
Connect (414-01 Battery, Mounting and Cables, General
Procedures).
3. Remove the transmission.
For additional information, refer to: Transmission (308-03
Manual Transmission/Transaxle, Removal).
4. Disconnect the fluid pipe.
Position an absorbent cloth to collect any fluid spillage.
Remove the clip.
Part #2 in the blowup below:
Post #316560 17th Mar 2014 8:45am
Naks
Yep, the culprit is the slave cylinder, which is being replaced.
This Ford design is a real PITA, it is the same on the Fiesta/Focus as well. --
Post #316902 18th Mar 2014 2:02pm
