![]() | Home > Technical > Rear End "Clonk" |
| Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335
See how much play there is on the diff pinion - grab the prop and see what moves!
Could also be any of the other rear bushes - trailing arms for example. |
| Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288
My bet is play on diff pinion splines. Take off and put back on with loctite was the technical repair!
If not rear drive flanges worn! |
| Marky Boy Member Since: 25 Oct 2013 Location: Maidenhead Posts: 96
Thanks very much. I have just checked the Haynes manual and it shows the rear drive flange and half shaft as one piece, can you confirm this is complete tosh ?
Apologies for the newbie question..... |
| derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567
Earlier ones where one piece but the later ones have separate drive flange.
Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
I have a clonk that is rather helpful as when I get a clonk I know that I forgot to grease the prop. Id say start at the props first as its a damn sight easier to attend to and potentially the cause
Thankfully Saturday looks nice, I think I'll be I under the Defender then. Thanks for the replies, glad the Haynes manual is right
