![]() | Home > Puma (Tdci) > Air conditioner servicing |
you are supposed to change the filters , drier etc but no one ever does if everything ok ( no pump problems etc )
normal ac service is : remove gas weight it and make sure not lots leaked out then vacuum system ( 25 mins ) to remove moisture then measure amount of oil removed ( you can't remove all the oil unless complete strip down or flush ) machine should do leak test if ok then fill with gas and add bit extra oil then removed and if it was a bit low on gas but passed leak test you can add a small bit of uv dye to aid leak finding in the future , then run and check pressures with ac on and put a ac bomb in cabin to freshen it up and kill the bugs in the air pipes you normally find ac will work better after even if it was full of gas really should be done every 2 years they say even a good system with no detectable leaks will lose 10% gas a year don't be tempted to use a small top up can from motor factors most have sealers in them and it will never work as good again |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
Most manufacturers recommend air con is serviced and re-gassed every 2 years. Local garage did my Puma because the stealer was too expensive.
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
I turned the AC on the other day (could not find a balance between hot /cold so had to turn tha AC on) and there was a strange smell coming inside the cabin- like mold or something - that dispaear after five minutes or so... But it was not the first time... So I was wondering if there are any filter for the Vent/AC that should be cleaned or changed? You mentioned this, can tell where they're located, or how to? Page of the workshop manual perhaps ? (Did look but could not find ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
no pollen ( CABIN ) filter on puma
you need to put a aircon sanitiser (sometimes called a aircon bomb ) through it its like a aerosol spray that you set off inside then close doors (DONT SIT IN CAR ) with aircon running and it kills the mold etc in the system. FOLLOW INSTRUCTIONS ON THE AEROSOL FOR EXACT WAY TO DO IT |
Condensation left to stagnate on the air-con condensor is often the cause of bad smelling air-con.As said, look for "air-con bomb". Like this. http://www.micksgarage.com/proddetails.asp...p;pk=521af Pov.spec,ftw. 2006, 110,TD5. |
no pollen ( CABIN ) filter on puma you need to put a aircon sanitiser (sometimes called a aircon bomb ) through it its like a aerosol spray that you set off inside then close doors (DONT SIT IN CAR ) with aircon running and it kills the mould / bacteria etc in the system. FOLLOW INSTRUCTIONS ON THE AEROSOL FOR EXACT WAY TO DO IT |
Usin your air-con a lot is a good thing,it helps stops the rubber hoses and seals from perishing. Pov.spec,ftw. 2006, 110,TD5. |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
I personally use my AC all the time. Keeps the inside nice and dry, especially with the wet winter we have experienced.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
I`am aware there is no pollen filter fitted as standard and to the best of my knowledge I`cant see where it may go.
Is there a aftermarket or harsh conditions filter option out there as I`am not to keen on the smell (so far so good) when it arrives. It will get air bommed. Just watch the plastics I`ve seen a dash badly marked by them. I was wondering about making a pollen filter myself to go over the heater motor intake and measuring the motor current draw to see if it made a difference. Has anyone any ideas... |
Devon 4x4 do a pollen filter.
![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Fitting a filter wont help with smell . The smell is coming from inside aircon system
Change your undercrackers!
![]() Treat every day as if it is your last....one day you will be right!! |
Thanks for that steve will have a look at there site, always get hay fever every year, hope fully this will either slow down or stop the nasties lurking in the evaporator.
Go commandooooooooooo... |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2255 ![]() ![]() ![]() |
Sorry old post but am i right in thinking it sits below the NS wing top grille?? |
