![]() | Home > Technical > Puma Alarm BBUS Siren and Loom |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
may only come on sw , not sure
| 110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158
Yep its for the self leveling head lamp motor
Slide it left and it will pop out I used a rod or stiff wire to push through the repeater hole to the front taped the wire on and pull back through
| kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1323
Thanks John - will have a go tomorrow.
Also the old harness is secured in two places by a pointed plastic clip which pops into a hole. How did you get these out? |
Well its clipped in 3 places I used the rods i have to enter from the hole up by the heater fan pushed it to the front taped the wire harness to it and pulled it back through because I didnt want to remove the plastic covers in the wheel arch therefore Ive just left the old harness in situation unplugged and taped up and tucked away behind the water bottle you could tyewrap the new harness to the old harness at both ends
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
No chirp, just the indicator lights flashing on arm/disarm. |
Yep makes sence as the horn dont beep suppose if i had the door open and tried to arm it would chirp as the horn beeps twice just to test thats all
Interesting question - I'm not sure if the mislock beeps the horn and the BBUs or just the horn. If you set the alarm off then both will sound (unless of course the battery is disconnected in which case on the BBUS will sound).
