![]() | Home > Maintenance & Modifications > Stainless steel EGR blanking kits |
| Robofarmer Member Since: 17 Mar 2010 Location: cheshire Posts: 88
Top man fekete full breakfast for me everytime too !!!! ex 1988 defender 90 ,td ex 1970 series III |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Well had the 18mm blank on for nearly a week now. No MIL light and may be my imagination but appears to be marginally more economical (will see with next fill). What isn't imagination is how much quieter the engine is! Will wait till I get my remap back on and go a size smaller. Shouldn't be too difficult now the studs have been removed and replaced with the ss bolts 10-15mins I reckon.
Hands are healing nicely having ripped 'em to shreds trying to clear the studs to get the blanking plate on last week instead of just removing them! Happy days! Treat every day as if it is your last....one day you will be right!! |
| mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286
Completely understand about the scars, mine are healing now 1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2510
Suggestions?
doesn`t look very promising for my knuckels. Should I remove the expansion tank to start? cheers M Puma 110" SW ............................................................. Earth first. Other planets later |
MK,
No need! Just buy a bottle of antifreeze and disconnect the pipe at the bottom of the expansion tank it will give you enough room! If you've got some gloves put 'em on! There's lots of sharp edges and it'll save a week of healing! If you've got studs remove them rather than try to get clearance to fit the blank and replace with the bolts! Took me a while and a couple of calls to Robofarmer to get it done but it shouldn't really take more than 30-40 mins first time! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513
K9F - if you're changing your plate, maybe you could take some photos of the job + New Defender 110 First Edition |
From AndrewS` pics I can see original bolts still there
Alantd,
Job took longer than expected and I had to get vehicle back together to get back to work. Unfortunately all was a bit of a panic and I didn't take pictures. Got 2nd service in 2,500 miles so will have to swap back, will take pictures then if someone hasn't beaten me to it. MK, On Andrews's photos they are the original studs (not bolts) he has just removed the nuts off them to facilitate removal.... Some vehicles have studs fitted where you just remove nuts to undo, others have bolts that you just extract. The difficulty of the task depends on whether you have bolts or studs as original fit If you have studs fitted you have to make sufficient room to pull the EGR Valve assembly clear of the manifold to fit the blanking plate. I couldn't manage this as I have aircon and could not obtain sufficient clearance with all the pipes etc. Quick call to Robofarmer and he said "Use a star type socket and remove the studs completely and replace with the bolts I supplied!" Makes the job and any subsequent blanking plate fit/removal much easier. Hope this makes sense. If you've got bolts as standard just whip 'em out retain the gasket and replace with a blank. Job jobbed! Treat every day as if it is your last....one day you will be right!! |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
it's sufficient a little modify....
off course the photos is only the idea, normally we make this kind of solution on Gas & oil plant blank/cut-off plates Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
IID Pro MV License |
Mk def no need to take the expansion tank off just try and do the job with engine cold to start with would be best!. If you do end up change,n a plate after a run just wait a reasonable amount of time for engine and water temp to cool a little and then release the expansion tank top slowly for a min then tighten again and then squeeze clip and remove black water pipe out of your way. and you should,nt lose more than a cupfull of coolant . ex 1988 defender 90 ,td ex 1970 series III |
I know those jobs I need a mechanic's "undo" button. + New Defender 110 First Edition |
Alantd, Your post is creepy!!!! You were watching me and listening in weren't you? Wonder how many others use the "It'll only take me 10 minutes, honestly!" and the accompanying "It's all gone horribly wrong!" Treat every day as if it is your last....one day you will be right!! |
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
how are people geting on with this iv just ordered mine
what is the best size to start with ? and any one got any real good storys of what the performance has beeen like after fitting cheers steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
