![]() | Home > Off Topic > Gas Boiler engineer |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Hi what problems are you having? Iam nowhere near you but may be able to talk you through something?
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Mynstral Member Since: 14 Feb 2012 Location: Essex Posts: 119 ![]() ![]() ![]() |
![]() Click image to enlarge Hi Bear100. The boiler is 3-4 years old now. Every so often (every 20-30 demands) there's a loud knocking banging noise, system shuts down, need to press reset to hopefully restart it. Also has a very orange flame when lit. See photo. Regards Myn. Smoke me a kipper I'll be back for breakfast. |
British Gas first fixed mine (in about 10 minutes) when I bought my (new) house 16 years ago, after the local plumbing company that originally installed it first time round refused to deal with me and started blaming Potterton (they had a point ,Potterton, another British company
From what I can see in the photo your burner looks like it has a lot of crap on it, you should have a blue flame with no glowing orange or yellow bits, I would have thought the loud banging noise is from a failed attempt at lighting causing explosive ignition, has it been serviced? Could probably just need a service £40-70 ish 2023 Defender L663 V8
Thanks all. I'll give British gas a call. Of get me a large hammer. Lol
M. ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
Ours keeps loosing pressure periodically about every month or two the pressure gets so low it stops as the safety turns it off. I keep topping it up to the correct pressure of about 1.5 bar and it keeps dropping.
Not that the landlord will listen of course... Even though they are raking in 18 million £ profit a year... ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
/\/\/\18 million,how big is yer house??
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Check Radiators for leaks, also you will get small amount of air in the system when you top it up. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Shall have to do that I thought I have before but still does it.
![]() 18million is last years Duchy of Cornwall profits... Despite recession and avoiding tax AND putting rents up. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ Last edited by custom90 on 7th Mar 2014 2:39pm. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
I know that I probably shouldn't have, but for the last 27 years I have serviced my own gas boiler. It isn't difficult.
There are only a few things which will cause pressure to drop,
Obvious first a leak, Prv (safety valve) passing, Expansion vessel faulty causing pressure to build and activating the prv Gas forming in side the heating system due to corrosion or reaction. Putting fresh water into your heating system on a regular basis is very bad, oxygenated water will cause your radiators to rust from the inside out and you won't know until one bursts!! 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
The boiler is brand new so I'm guessing it's a leak in the system, shall have to check it all. I know they are all bled that's for certain. ____\We|Will|Win/___
[quote="ARC99"]
Check Radiators for leaks, also you will get small amount of air in the system when you top it up.[/quote THIS /\/\/\, Over the first 10 years or so, I replaced ALL of the thermostat valves on the radiators,which stopped the excessive annual bleeding I used to do, allways when winter started,again coz of the a55hole cheapskate builders/plumbers. Pov.spec,ftw. 2006, 110,TD5. |
Heating safety went on again tonight due to pressure drop, I then went and checked for leaks especially a suspect nut (that's caused the same problem in the past) on a radiator inlet valve. Low and behold it has been leaking as it was wet and the nut was loose, luckily not leaked too much though. I've since tightened it, checked that there is no air in the radiator and re-pressurised the system. Hopefully that has sorted it. For some reason that same nut has done the same thing before, it's the only one that has ever done it too. I'm thinking taking it out and some PTFE tape on the threads would help stop this happening? It doesn't leak when tightened but seems to become loose of its own accord for some reason. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
