![]() | Home > Td5 > TD5 cruise control kit |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Anybody on here making one yet for the TD5? I see terrafirma are doing one but i dont know how much it costs??
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
Get yourself a few lengths of cable,some switches and read all about it here <----
Apparently Pete was (in some other posts on here, or maybe it was LRA) attempting a fix to this problem. either he or Porny should be able to fix it. |
Whats the reason for this?
Ive got standard gearing because i tow a lot but interested to know why it makes a differents!! |
Apparently the Td5 ECU has pre-programmed limits for stuff, and it knows that say, for 70mph it has to be doing 3500rpm (as an example, i don't know what the revs are for that speed)
Now, if you fit an overdrive or a 1.2:1 t/box, (as i have), then you could be doing 70mph at, i don't know, 3000rpm?, so the ECU will think "hmmm, that's outside of my parameters as a Td5 with 1.4:1 gearing should be revving at 3500rpm.... something is wrong" and won't let the cruise work. Whether this works on all ECU's i'm not sure, and whether the above is 100% accurate, again not sure, but that's the way i understood it when Pete was talking about it on here, and when i've chatted to Porny. |
That makes sense.
Thanks. |
jools Member Since: 23 Feb 2010 Location: Devon Posts: 47 ![]() ![]() ![]() |
Fitted mine over the weekend.....
Tip of the day The instructions say: "From inside the engine bay......feed the 2 core wire through the bulk head..... From inside the cab, find the end of the 2 core wire and feed it safely......." Yeah right!!! - It just coils itself neatly out of sight!! ![]() So my tip of the day - Use some nice brightly coloured nylon strimmer cord to feed through the bulk head. Its quite stiff and doesn't coil itself away - and a nice bright green in my case was easy to spot. Once its through and you can locate it you can then tape the 2 core wire to it and pull it through - perfect. ![]() Anyway - all fitted - been on a test drive and seems to behave exactly like my Freelander CC did Obviously no light on the dash to tell you that its engaged (like the FL) - but a slight touch to the brake, clutch or the button itself and it disengages Taking the Landie to work tomorrow - so will give it a run chugging down the A38 somewhere between 55-60MPH Jools 2003 90 XS SW Support Devon & Cornwall 4x4 Response - www.buy.at/dc4x4 |
Glad my kit worked well for you, i might just include your in tip in future instructions!
Pete. |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1912 ![]() ![]() |
Zinke's kit is great - well worth doing
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
is there a kit for the puma ?
pom |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2685 ![]() ![]() ![]() |
See this thread for a quick DIY setup: http://landyonline.co.za/landyforum/viewtopic.php?f=5&t=3230
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Yes ![]() |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 ![]() ![]() ![]() |
Aha, where can we find more info on that
![]() Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
I was expecting to read a topic about one of these resting against the throttle pedal...
