![]() | Home > Puma (Tdci) > xs heated seat element (round thing) |
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 ![]() ![]() ![]() |
there is a wire going into and one coming out you may have broken one of the wires which will stop both the back and base working as they both work as a circuit together
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 264 ![]() ![]() ![]() |
I think its some sort of sensor.. power goes in but not out. For the time being i've cut it out and its working. Need to find a replacement.. might try maplins.
look here
http://www.rangerovers.net/repairdetails/s...grade.html May be this is your switch http://www.digikey.com/product-detail/en/c...ND/2195521 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
