![]() | Home > Puma (Tdci) > Noise from behind headlight |
| Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125
After turning engine off but leaving lights on (by mistake) I noticed a noise behind the headlight which stops when the lights are turned off and starts again when lights are turned back on. It sound like a mini compressor running. Any ideas?
| gprich Member Since: 14 Jun 2013 Location: East Devon Posts: 42
What sort of noise
Sorry just edited the original post
It's just on the one (passenger side) I'll go and check it now.
That's what it is, changes tone when the switch is put to different positions. Goes off when the lights are off and back on when lights are on.
| Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2791
It'll be the motor yeah, leave engine & lights on for a while and it'll get to the right level and turn off Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
My headlight motors on the 2008 needed to be replaced as they had a mind of their own. Always went to lowest position on turning off the vehicle. On starting up they would EVENTUALLY return to normal height of their own accord, irrespective of the position of the intereor adjustment knob. Was not too good setting out at night with headlights pointing into the ground waiting for them to pop up to normal height! 1982 88" 2.25 diesel
