Home > Puma (Tdci) > surge of power and blue smoke
lee cun
Hello guys I own a 2009 defender 90 with just under 60.000 miles I've owned her for nearly 2 years now and there seems to be a problem some were. It's when you first start up on a cold start, blue smokes appears not lots but a puff every couple of seconds. And if you put revs on a little the engine will shake likes it's spluttering a bit. And when you drive there is a power surge for a second or 2. When you are in between 1 and 2 thousand revs. I have no lights up on the dash and this problem seems to happen 9 times out of 10. But the odd time she will run fine. I changed the fuel diverter valve last year as didn't idle smoothly could anyone help!!! Many thanks lee
Post #313890 6th Mar 2014 9:35am
Cheshire110
Do you have access to any fault code reader?
Also, check your oil level? Some vague part of me wants to say oil in fuel?
Edit: I'm no expert, just have a vague recollection of something about oil in diesel and power increase and blue smoke??? Cheers, David
Post #313895 6th Mar 2014 10:04am
munch90
could be sucking bit of oil thru breather that will give blue smoke , rattle , power surge
Post #313896 6th Mar 2014 10:10am
Bluey whiteish smoke on cold start seems to be a fairly common TDCi feature. I don't think it is anything that should cause too much concern.
Post #313901 6th Mar 2014 10:44am
lee cun
Re: surge of power and blue smoke
thanks for the replies guys. I checked oil thethe other day and it has moved 2mm in last 2000 mile. The blue smoke smells rich like to much fuel. But I'm no expert on this. Also the smoke will go when I set off and then the surge in power will come. I can't get codes any unless I take it in to garage some were thanks for getting back every 1 think this is how I get back to every on just joined this site ha
Post #313914 6th Mar 2014 11:16am
Cheshire110
Mine definitely doesn't give blue smoke or surge, unless I start it without the glow plugs on a cold day (still doesn't affect feel or noise, just a puff of blue smoke) Cheers, David
Post #313915 6th Mar 2014 11:16am
Cheshire110
It may be worth borrowing or otherwise acquiring a simple fault code reader. I've got a bluetooth one (eBay search bluetooth obd) which works with any one of a number of (often free) smartphone apps.
It should at least let you know if there are any trouble codes recorded. Cheers, David
Post #313922 6th Mar 2014 11:27am
lee cun
Ok thanks I will do so
Post #313926 6th Mar 2014 11:56am
Naks
blue smoke means it's burning oil.
get that seen to asap. --
Post #313935 6th Mar 2014 12:21pm
lee cun
Hello, ive just been tinkering with my friend who has a fault finder and we plugged it in and it came up with no faults. I also pulled off the oil breather pipe from the air box and checked for Any oil. There was a little on the side of the pipe going to top of engine. I was thinking of taking her for a drive with the breather pipe disconnected would that do damage to anything? Or is that a no no guys.
Post #314034 6th Mar 2014 8:07pm
