![]() | Home > Puma (Tdci) > Grease Points For Puma |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
3 each prop. 1 each UJ+1 on the sliding splines Puma 110" SW
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
From memory (what's left of it) mines only 1 on each UJ. The fronts were a pig to grease so I put extended nipples on and now it's much easier.
I suspect they never ever got greased by the stealer during warranty servicing. AlanH. |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
What grease goes in these??
As stated above there is a nipple on each UJ plus one on the sliding splined part of the shaft, so 6 in total. You may find that one or more of the nipples has fallen out (there was a service bulletin on some models for this).
Any good general purpose lithium or molybdenum based grease will do. I use Castol LMX* (which used to be Castol LM, which was every manufacturer's preferred general purpose and wheel-bearing grease for about the last 150 years, but I think has recently been discontinued). You will get a much better result if you unbolt at least one end of the propshaft prior to greasing to that you can articulate the joints fully and extend and retract the splined part to get the grease distributed properly. It also allows good access to the nipples with a standard grease gun. The WSM does of course say that you shouldn't reuse the flange nuts, but in practice they can be used a small number of times (2 or 3 at least) without risk. The nuts are standard 3/8" UNF Nylocs and a bagful from your local fastener dealer will be cheap in comparison to genuine parts. * Edit: now superseded by the imaginatively-named Castrol High Temperature Grease No 2 |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
Prop shafts don:t (always) have nipples on them, some (mine) are sealed for life versions.
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 ![]() ![]() |
You CAN'T just use any old grease... Different types of grease react with other types of grease. They break down and become useless as a lubricant... Always best to use what the manufacturer has specified unless the grease has been changed.
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
I use a lithium general purpose one. Its black and not very thick and I find one pump of the grease gun lever every 4 months does the trick ie you see grease just starting to ooze out of the gaps. Its not a job I look forward to though. MY11s don't have sliding joint nipples so you're at the mercy of the assembly guys
Right Rossy. Having to rely on them possibly having been done by whoever puts these things together is not a happy thought.
AlanH. |
Graphite grease
Simon27 Member Since: 30 Oct 2012 Location: East Lothian Posts: 131 ![]() ![]() ![]() |
Mine only has the nipples on the UJs and not the sliding part.
Would it ever be worthwhile unbolting one end and sliding the 2 bits apart and apply grease to the splines? |
Extending the shaft to grease the splines wouldn't do any harm at all, but don't pull the halves completely apart since the alignment is important.
You're sure the shaft isn't drilled for a nipple that simply isn't fitted? Definitely a backward step if not. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
No grease points on the slider of my front or rear props
![]() ![]() And very strange grease nipples on the front uj's that you can't get to. So doubt they have ever been greased ![]() ![]() Andy |
HMARR Member Since: 04 Jun 2013 Location: New Zealand Posts: 56 ![]() |
My front props also had some strange nipples on them (that sounds dodgy) they were different to the back ones and apart from being very awkward to get to, they seem to need a different fitting to take the grease gun... ARRRRGGG!
I had to unbolt one end of the prop, swing it about so I could grease both uj's. Think I'll be getting two new props in the future.
![]() Andy |
