Home > Puma (Tdci) > CALLING ALL ELECTRONIC EXPERTS
zs1sam
South Africa 2011 Defender 110 Puma 2.4 SW Alpine White
Greetings to all from sunny Cape Town!
Here is a brief description of the problem: 2011 110 Puma; 2nd battery fitted professionally with a National Luna split charging system; 2 power points fitted at the rear of the vehicle. One power point used to power a National Luna fridge / freezer which has a Danfoss compressor.
The problem: I am a radio amateur (HAM); fitted in the vehicle is a HF transceiver. Power for the radio is direct from the 2nd battery. When the fridge is running and the radio is on, there is a very high level of interference on the radio. If I switch the fridge off, no noise.
Simple solution is to switch the fridge when transmitting; however, I have, at times, forgotten to put the fridge back on. Besides my beer not being ice cold, I also have an irate wife!! Rolling Eyes
Any solutions??
Sam
ZS1SAM
Post #313669 5th Mar 2014 8:33am
K9F
Sounds like the fridge's motor is not suppressed. Have a read of this:-
http://www.vishay.com/docs/26529/gentecin.pdf If you go through life with your head in the sand....all people will see is an ar5e!!
Post #313674 5th Mar 2014 9:01am
Cold_n_Wet
Norway
Hi Sam,
sounds like a similar problem I had in Bots last summer.
Ferrites on the power line to the fridge may help.
Glen
LA1ZUA
(was ZS6/LA1ZUA and A25-LA1ZUA) "Rafiki" 2007 110 STW - Rolling rebuild.
Post #313732 5th Mar 2014 2:26pm
zs1sam
The following appears to be the solution. It may help others HAMS who also operate fridges/freezers with Danfoss compressors.
All fridges using the Danfoss compressor are notorious when it comes to the rf noise issues. The secret is to use a mains EMI filter, basically a small module which gets inserted inside the fridge in the power line (both positive and negative goes through it), and it's casing get connected to the metal casing of the fridge.
The noise you hear on the radio is caused by the compressor controller, and radiates through the 12 volt power cable connected to the fridge. The filter absorbs the rf and stops it from getting out of the fridge.
Thanks to those who responded
Sam
Post #313775 5th Mar 2014 6:34pm
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Maplin in the UK do a cheap mains RFI filter module
http://www.maplin.co.uk/p/delta-suppression-filter-rg21x
I have used these with great success for all kind of noise problems and only £2.99 so not a bank breaker if it does not work for you. 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #313787 5th Mar 2014 7:46pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Try this....
http://www.defender2.net/forum/topic26844.html ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #313855 5th Mar 2014 11:57pm
