![]() | Home > Maintenance & Modifications > Anti Roll bars after 2" lift |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
buy some extended drop links, or make some?
landydubai Member Since: 01 Sep 2010 Location: Dubai Posts: 206 ![]() ![]() ![]() |
Thanks TIG UP
Any ideas where I can buy some Have destroyed the rear bushes already ![]() Keep the shiny side up! 09 110 XS BAS remap 09 90 pick up BAS remap 08 D3 V8 G4 Spec Bentley Speed GT 2009 G55 2003 Ford Raptor 2010 - new toy! |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2683 ![]() ![]() ![]() |
Hi
http://www.extreme4x4.co.uk/acatalog/ALUMINUIM_SPACER_BLOCKS.html One my last 110 i uprated the shocks and did not feel the need for anti roll bars so took them off. Hope this helps you or perhaps you can get them made locally Cheers Mark |
Thanks Mark
![]() ![]() Keep the shiny side up! 09 110 XS BAS remap 09 90 pick up BAS remap 08 D3 V8 G4 Spec Bentley Speed GT 2009 G55 2003 Ford Raptor 2010 - new toy! |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
Is it possible/good idea to fit a paddocks anti roll bar kit to a td5 90 with a 2 inch lift? Any other kits, feedback most welcome
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
Depends what you want. Is lift for looks or use? If looks and it does mainly road work fit ARB spacers. If got off road use, remove ARBs, to get better articulation.
Andy |
Thanks Andy
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
LandyAndy - old thread, but wanted to know if you ever found some extended drop links?
