![]() | Home > Maintenance & Modifications > No drill lightguards? |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
The plastic headlamp surrounds are held on by the side light and indicator screws plus two screws going through the headlamp surround. These two screws go into square plastic plugs.
On the other side of the headlamp there are another two corresponding square holes in the bodywork. The Entreq range of light guards use the existing two screw holes in the lamp surround and two small holes have to be drilled in the plastic lamp surround and two fresh plastic square plugs inserted into the existing holes. Hope that makes sense. Brendan |
paulnb57 Member Since: 18 May 2011 Location: Isle of Wight UK Posts: 38 ![]() |
As stated the holes are there for Series style headlamp surrounds, did you search for Series guards?
These are them but the sale has ended http://www.ebay.co.uk/itm/Land-Rover-Headl...7675.l2557 Perhaps Dunsfold could help? Paul |
