![]() | Home > Technical > Timing belt ? |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Might be worth buying the proper kit its not that expensive and makes it much easier.
http://www.ebay.co.uk/itm/15-Piece-Diesel-...1c2e041188 |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 365 ![]() ![]() ![]() |
On a 300 Tdi it's a 9.2 to a 9.5mm drill bit.
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Yeah thinking about it I think it was a 9.5 drill bit come to think of it
![]() ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
Yeah but all I would use out of it would be the locking pin for the fuel pump sprocket but as for locking the fly wheel and crank in place the engine is no different than a series ( old school ) engine aslong as you keep a mental note of where the crank and cam has moved to whilst working on the engine to where they should be when fitting the belt shouldn't have a problem have replaced the timing belt on a 200tdi and a 300tdi in the past but the last was about 5-6 years ago but forgot what size drill I needed to lock the fuel pump sprocket in place with ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
