![]() | Home > Tdi > Clonk when changing gear. |
Tia4 Member Since: 15 May 2012 Location: Surrey Posts: 48 ![]() ![]() ![]() |
My 300tdi that has covered round about 108000 miles has started to make a noise when I depress the clutch pedal and change gear and again when I release the pedal this occurs in all gears not sure where to start looking or how also a bit concerned if it could cause more problems if I drive it to far now I have noticed it.
I also have a problem with my speedo I am sure it reads to high and also at lower speeds it jumps around a lot and does not settle back to zero always rest just below the 10 mph mark (I know it's not to much of a problem does make me think I have got a very fast defender though) |
Check your propshaft flange bolts.
Check your A frame ball joint. ![]() |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
Also check bushes and the state of your diffs.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6708 ![]() ![]() ![]() |
I had a horrid clunk which I had down as a failing prop or diff. Turned out to be the A-arm ball joint.
If doing it yourself I can thoroughly recommend the OEM quality complete fulcrum and ball joint assembly, rather than farting about trying to extract the corroded-in ball joint. ![]() ![]() |
Hows best to check the A frame bush
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 ![]() ![]() |
Lie underneath the car and get someone to rock the defender back & forth, check all your bushes as he's doing it. That's how we establish what bush if was if that makes sense?
![]() 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
muckybeast Member Since: 07 Mar 2014 Location: kildare Posts: 13 ![]() ![]() ![]() |
I had the very same symptons on my td5 turned out the half shafts and flanges were badly worn all changed now and the clunk is gone
