- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Caterham
Lorryman,
before I go jumping in with both feet. the photos you sent prior to bulletin are the result of a retro fit? How different (if at all) is this to one that left the factory without the need for the retro fit? ie is it only the the retro fit jobs that have the coil fuse things?
many thanks for all your help.
25th Feb 2014 10:00pm |
Lorryman100
Yes the pictures show the modulator harness link fitted. The ferrite fuse is the give away to the repair being carried out.
26th Feb 2014 4:03pm |
Caterham
spoke to LR today and apparently mines been checked for the harness mod / bulletin and following this they decided the turbo would indeed need to be replaced
so looking forward to getting my hands back on def now.....I hope they've given it a jolly good clean too
26th Feb 2014 9:36pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
