![]() | Home > Puma (Tdci) > Why is air intake on side of wing and not the top? |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
Discuss..........
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
Rain?....
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Rain, Snow, Leaves, all the reasons your heater intake blocks up- hence the snow cowl.
For me thr true question is why dont they come with an integral and water tight snorkel as standard?
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Still toying with the idea of moving my air intake to the top of the wing and covering it with a snow cowl.
Meee too!
To be honest, very few people actually need them as most defenders live there life on dry land. If you are going in deep enough to worry about your air intake being submerged then most likely event is your ecu's are already underwater, along with your floor mats, Battery compartment, fuses, axle and gearbox breathers so the damage may have already been done.
I can't see how much difference a few inches will make in the long run |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
The air intake used to be on top of the wing on 2.5 N/A and i believe V8. It moved to the side with the launch of the 2.5 TD engine. 2005 Td5 90 XS
Steve |
It's more about a clearer, shorter run for the intake of air than for extreme fording use. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
I think the intake was just on the airbox under the bonnet. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
The major issue with the air intake's location is that it is right by the front wheelarch and sucks in all the dust when driving on gravel roads.
This is why most owners in Africa/Oz put on a RAI as soon as they buy a Defender. You do not want to see an air filter after driving 1000km of Namibia's finest gravel roads without a snorkel ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 ![]() ![]() |
Correct. My pre turbo 110 has no side vents and no wing vent (other than the heater. All it had was the oil-bath air filter. The air was taken in around the top of the filter housing which was up near the top of the engine |
Same as the 2.25 diesel in my S3
Yep, my 110 was originally a 2.25 diesel too
