Home > Wheels & Tyres > tyre repairs and disposal
Page 2 of 2 <12
leeds
Eric, to my knowledge there is no simple test to decide if a tyre is SAFE.
However a visual inspection could show that a tyre is UNSAFE.
Just because a tyre does not LOOK unsafe does not mean it is SAFE
If you read the link Gum put up
Quote:
He said recommendations from manufacturers said tyres should not be fitted to cars if they are six years old, and should be replaced if they are 10 years old.
He said that this was not a legal requirement and that it did not apply to coaches or lorries, which was "frustrating".
BFG recommend tyres should not be used after 10 years old.
New tyres should not be fitted if more then 6 years old.
Brendan
Post #310995 23rd Feb 2014 7:47pm
ericvv
Brendan, all good then. No doubt that I will replace both my winter and summer tires before they will blow out 10 candles.
But for now, as said, with perfect visuals and gentle driving only they should remain ok for a few years to come. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #311169 24th Feb 2014 6:13am
Mdm
Just to give some info on truck tyres
Michilen truck tyres are used till there 2-4 mm then recut.then you send them back for a remix which is basically a retread. This again can be used until it's recut and then sent back for a final remould called an encore again this can be ran until it needs cutting then finally it gets retired
http://www.michelintransport.com/ple/front...mp;lang=EN
Loads of info online.
I know it's not car tyres but I have been to stoke and seen the process the tyres go thru and each casing is x rayed and goes thru a surprising amount of qc checks.
Post #311419 24th Feb 2014 10:19pm
[quote="ARC99"]
munch90 wrote:
I had a set of tyres on my old Disco, they were 8 year old and hardly used, It went in for a MOT and it failed on tyres as they were passed the recommended age.
I'm not aware that there's an actual reason for rejection based solely on the age of a tyre - are you sure it wasn't the physical condition but due to age?
Brendan's point on the age of new tyres begs the question of how many people look at the age of the new tyre when it's fitted?
Post #311531 25th Feb 2014 4:14pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Nothing wrong other than the age. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #311544 25th Feb 2014 5:29pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Checking the age of a tyre is not part of an Mot test and should not be a reason for refusal of a test certificate. In fact a tyre can be so old the sidewalls have badly perished and again that is not a reason to refuse a test certificate or even note it as an advisory. Surprised
Post #311575 25th Feb 2014 7:56pm
munch90
can be perished but are failure if you can see the cords
pumped up the front tyres on tractor yesterday , there perished that bad if it wasn't for the inner tube I would be able to see right through them .
time for some new ones I think
Post #311662 25th Feb 2014 10:09pm
scotsstag
Scotland 2004 Defender 90 Td5 CSW Rutland Red
Two or three years left in them yet Munch, get some gators in em.. Laughing Whistle 04' 90 Td5 CSW..
Post #311855 26th Feb 2014 1:19pm
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
GUM97 wrote:
Quote:
The burst tyre had a dot code giving its age and caused the accident as it finally failed, he said.
So, my immediate thought on this thread was: I picked up my Landy second hand, and have NO idea how old the tyres are -- three GG TR, one Nokian IIRC with a similar tread and a BFG AT as the spare ( Rolling Eyes I'll think about that next time).
Off to Google to look at tyre dot codes ... 2009 110 XS Station Wagon
Post #312097 27th Feb 2014 4:29pm
Page 2 of 2 <12
