Home > Maintenance & Modifications > Steering Issue
discocuzzy
Steering Issue
Got a real problem with the wagon, the steering has all of a sudden gone very stiff in one area per revolution of the wheel and its so bad you really have to struggle to get it to turn but once past it it frees up again until the next revolution of the wheel.
Now when it was new i hit a bad pot hole that put the steering out and knocked the steering wheel off center, had the tracking done and the wheel back central and has since developed this problem.
AJS 4x4 kindly looked over it and suggested it was the lower steering UJ that has siezed in one spot hence the intermittent stiffness but wondered if anyone else has had similar?
Call to dealer tomorrow to book in Big Cry You cannot teach stupid people to do clever things
Post #31101 30th Apr 2010 12:04am
jddisco200tdi
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Try some WD40 on the steering uni to see if this temporarily fixes the problem, then you will know whether the uni is at fault or not. Regards
John D - Defender 110 2.4
Post #31104 30th Apr 2010 2:59am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Sounds very much like a UJ. That would definitely explain the stiffness in one part of the rotation.
I guess that if the steering box was knocked out of allignment then it would have the same effect but you'd probably expect other symptoms.
That must have been one hell of a pothole! Given that the LR is capable of rock crawling and I've bounced mine (unintenionally) up some rather large curbs in the past, I'm amazed it knocked the steering out of alignment:!:
I assume you hit the hole with one wheel only. I assume also they've checked the connection of the steering rod to the wheels. It might be worth taking it off one wheel and trying the steering then - to see whether you're getting the same issue. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #31152 30th Apr 2010 10:30pm
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
I asked a while ago if anyone had a stiff area in their steering as it was the best way to describe it. Mine is about 2 o'clock to 3 oclock on the turn, where it is stiff, and then normal. It seems as if when releasing the wheel for return after a corner it wants to stay at a specific area. Is that what you are feeling as well? It happened after my accident in Feb where some of the under sterring mech was replaced. 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #31518 5th May 2010 6:44pm
discocuzzy
Exactly the same Thumbs Up, goes in tomorrow You cannot teach stupid people to do clever things
Post #31525 5th May 2010 7:42pm
johnnyturbo2002
Ok well, let us know what they said and what they did...
UJ or steering box? fix or replace and costs...please
good luck
John 2008 Defender 110 60 year Edition (sold unfortunately)
Post #31537 5th May 2010 8:44pm
discocuzzy
Steering box needed and will be fitted under warrenty...however they suggested that i might like to take it in next time on standard wheels and tyres and not wind the lockstops in Embarassed
Also need a new ABS unit and a rear diff seal You cannot teach stupid people to do clever things
Post #31617 6th May 2010 6:43pm
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Steve,
Did you take the diff guard off for the rear diff seal?
Did you go to Hunters?
Ian Thumbs Up
Post #31618 6th May 2010 6:46pm
