![]() | Home > Technical > Fuel warning light ? |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
Graham, that sounds faulty.
The light should only come on when there's approx 8-6 litres in the tank -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785
On older vehicles such as yours there is no proper damping of the fuel gauge, this means that sometimes when the tank has reduced in level going round corners or being on side slopes will affect your fuel gauge reading and bring on the low fuel light intermittently. Obviously as the level decreases further this will happen more frequently.
Used to happen on my 200Tdi, when below 1/2 tank and going round roundabouts the light would come on. Upgrading to Td5 instrumentation fixed it as it has far better damping in the sender circuit. According to the manual fuel light should come on when there's 2 gallons remaining. So basically no it's probably not faulty, just a "feature". |
| cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642
That's eggzackly what mine is doing but rather than fit a td5 gauge cluster would wiring in another fuel gauge but still use the warning light on the gauge cluster
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
