Home > Maintenance & Modifications > Defender Steering rubbing with Steering Guard ?
Ken B
Hi All,
Looking for a bit of guidance here, noticed a slight rubbing noise occasionally when out in the defender today. After parking up and scratching my head on what it might be I noticed this when inspecting!
It seems the connector rod between the steering and the damper is rubbing against my steering guard Rolling Eyes (This is on the drivers side wheel as seen from right in front of the tyre)
I had a good look around and cant see that anything has moved or broken but it is clearly contacting and a quick nudge on the steering wheel confirms that this is where the noise is coming from.
So any ideas on the underlying cause Question also not sure that i like that tight clearance between components so is this similar in other set-ups Question
 Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #310314 21st Feb 2014 6:16pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I have a few inches clearance, should not be that close. Have you moved anything in that area recently? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #310316 21st Feb 2014 6:19pm
Ken B
No not moved anything, i guess it may differ with different guards but something isn't right Defender 90 TD5 County -
Post #310318 21st Feb 2014 6:24pm
Happyoldgit
I have a Southdown guard that's now on it's 3rd vehicle, clearance is nowhere near as tight as that in the photo. TBH I'd not be happy driving it like that, if it were me I'd slacken the guard fixings to see if it can be better aligned, failing that it would be a job for Mr Angle grinder on the guard or remove it altogether. Steve.
http://forums.lr4x4.com
Post #310344 21st Feb 2014 7:40pm
jst
guards all vary. Southdown ones i run have a machined slot taken out of that area. best bet remove it and grind out 1" or so. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #310350 21st Feb 2014 7:48pm
Ken B
I haven't had a chance to investigate in any serious manner but not sure what it was like before hence query ?
I am seriously wondering if the guard has moved in some way Rolling Eyes although nothing is obvious from the visual inspection I think will need to unbolt a few bits and see what is going on as not keen to drive until resolved. Defender 90 TD5 County -
Post #310355 21st Feb 2014 7:53pm
leeds
Looking at that photo, it would appear to be a rather poor design and make.
A decent hit on the steering guard is extremely likely to be transmitted to the steering components.
That guard bracket looks like it is beginning to rust, maybe under electro plate?
Am guessing the actual bash plate is coated ali and the coating is coming off??
If you take an angle grinder to the bracket ensure you take some decent rust prevention measures.
Brendan
Post #310362 21st Feb 2014 8:05pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Is that a screw resting on the sump guard just in front of the lower nut?
If you grab and give it a tug does it move.
Post #310375 21st Feb 2014 8:56pm
Ken B
Hmm i think only thing to do is get some spanners on the job and look deeper.. It may be a bad guard but don't know as i din't fit it originally Question
clearly not keen on such a close fit and agree want to avoid a knock taking out the steering as it is a truck used for offroading on a regular basis so was quite surprised when i noticed that the clearance was non existent!!! Defender 90 TD5 County -
Post #310376 21st Feb 2014 8:59pm
Ken B
No that is some coating that clearly has been applied flaking off... everything is solid hence the confused thinking and it doesn't look like it has moved at all (although a knock could obviously shift it) I gave it a whack with a mallet to see if it moved but it wouldn't so will get the spanners out ASAP and see what is going on me thinks.. Defender 90 TD5 County -
Post #310377 21st Feb 2014 9:04pm
Ken B
Right inspected and cause found, it seems that it is pretty old and has suffered some wear and tear
A temporary solution has been to grind away about 8mm clearance to be sure that it wont make contact even if it wears further in the immediate / short term but will look into picking up a new steering guard as it has clearly seen better days
Any suggestions on a decent guard to fit on a D44 bull bar Question Defender 90 TD5 County -
Post #310571 22nd Feb 2014 3:17pm
