![]() | Home > Off Topic > INTERESTING, NOT A DEFENDER, BUT? |
sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147 ![]() ![]() ![]() |
what do you think?
http://www.mikeno.de |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
Designed by Lego?
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Not bad.
If the replacement for the defender was along these lines it wouldnt be so bad |
Kraut Member Since: 28 Dec 2011 Location: Westphalia Posts: 336 ![]() ![]() ![]() |
exactly first thouhght coming to my mind too |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6726 ![]() ![]() ![]() |
No real photos, all CGI. No prices, no nothing
around 30,000 euros for 110 utility equivalent
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 ![]() ![]() |
That is one fugly beast!
Uncas |
keep looking, then look at the concepts then at the design again, it will grow on you.
Nope, it hasn't
German engineering, galvanised chassis, abs body and with the strict TUV rules over there it looks like a viable vehicle perhaps? Would like to see one in the flesh. If you go through life with your head in the sand....all people will see is an ar5e!!
If they made the front a little nicer, I'd have one
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
If it's as good as I find it ugly it will be a promising vehicle!
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1733 ![]() ![]() |
I'd be interested to see one if there made.
Might just be me but looks very big/ wide so curious to see a scale shot to something real. Defender puma dormobile camper |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
The write up is good. Wades 800mm tows 3500kg. It's just over 2 metres wide wing mirror to wing mirror.
Looks very odd and can imagine it will be expensive. So as with most other options you may as well buy a d4. |
