Home > Maintenance & Modifications > Light Bar quandary sorted!
Leenorthants
The new led light bar turned up today. Deliberation started, where to mount it, didn't want it on the roof rack, couldn't mount it on the bumper as I couldn't access my winch controls, so wanted it mounted at the front. I didn't to cut the front grill. So I did the following.
Mounted a solid Ali bar behind the front grill, bolted on either side, with two 8mm bolts ready for the light bar.
[url=]
[/url]
Then grill on, I changed the bolts as they were 10mm too short
[url=]
[/url]
Then a nut and washer
[url=]
[/url]
Then all mounted and wired up, grill remains untouched and bar is solid!
[url=]
[/url]
Now waiting for night to check.
Post #309960 20th Feb 2014 4:58pm
Leenorthants
Some reason the pics are there, you just need to click on them!
Post #309961 20th Feb 2014 4:59pm
Tiger
Great pictures Thumbs Up
Post #309962 20th Feb 2014 5:00pm
MartinK
Re: Light Bar quandary sorted!
Cool :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #310016 20th Feb 2014 8:09pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I have most of the bits to do just this! Is it a 12 inch light bar? Where shouts did you bolt the alli bar at the side? I think my alli might be a bit too short! Rolling Eyes 1998 110 300Tdi White Hard Top
Post #310017 20th Feb 2014 8:25pm
Leenorthants
Hi, it's a 13.5" bar, my bar just bolts to the sides with a 6mm bolt. The bar was stable, but I also cable tied it to the slam panel bars that run diagonally, I did this for belt and braces and will put a small bolt through it in the future.
Post #310018 20th Feb 2014 8:31pm
