![]() | Home > Technical > Noisy idle,Posb Clutch? |
| General Lee Member Since: 09 Feb 2013 Location: Grahamstown Posts: 19
Sorry...that should be engage the clutch......
| 110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158
Could be the thrust bearing goosed
Im seeing mention of the clutch release bearing in other posts? Thrust bearing is inside the engine?............
Its in the bell housing if it is that it rattles untill you press the clutch pedal
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812
What year is your Defender... there has been a few clutch 'updates'? IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
| Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941
Mine is currently in for that exact same issue!
They have had it 4 days now and are still trying to diagnose. As soon as i have confirmation of what it is then I will let you know. They have checked quite a lot and are currently rummaging around in my transmission. Is a much more pronounced sound in cold weather =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
On the back of this post I called up for an update and they need to keep it again overnight, and were quite frank that the transmission is in pieces and being rebuilt, possibly over the weekend. This is where the knocking is coming from but have not highlighted a particular part as yet.
Hope this helps and saves you the hassle that they are going through isolating the issue, but doesn't look like it's good news. Mine is a 2012 defender so luckily in warranty =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
tHATS NOT GOOD NEWS......I was hoping it would just be a bearing.Mine is a 2008 Model.But lets see what the stealers tell you.Holding thumbs!
@ 110John- The manual locates the thrust bearing on the cam rocker inside the engine and the PILOT BEARING INSIDE THE FLYWHEEL.Is this maby the bearing you are talking about?
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752
If its a good rattle, and goes when the clutch is depressed, ie clutch disengaged,
I have just had the same on my 2008 lanner 90,, Clutch plate centre hub springs rattling/missing,, As Porney says,, numerious "clutch updates" Main Brian James Trailer Dealer for South West UK |
