![]() | Home > Puma (Tdci) > Testbook platform |
The Badger Member Since: 04 Aug 2008 Location: London ish Posts: 7 ![]() ![]() ![]() |
Im moving somewhere remote and am trying to get hold of some sort of computer to plug into my car...
( how weird does that sounds ), waiting on Test book then I guess? |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
You can buy (although I so so so strongly dont recommend it) blackbox £500 - they will get the harp out for you about how they only make £170 if you ask for support in under a month.
the new testbook platform is comming as is nanocom. You can buy autologic for £6-8k but that is good kit. So yes a little wait would be my suggestion Mike |
Yeah I think i will wait...
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
I have a resonably priced basic piece of kit that will supprot the puma, it realy does depend on what you are looking to do on what kit you actualy need.
My basic BAS Remap switch will give you engine fault codes and clear pendingor present DTC'S It will desplay the fault codes as a generic P code used by most manafactures nower days. With a quick google with the readout P code can be turned into wording that will help determine your cars fault or problem. http://www.obd-codes.com/trouble_codes/index.php or try something like this for a basic tool and goodvalue for money. http://cgi.ebay.co.uk/AUTEL-MAXSCAN-GS500-....m20.l1116 Admittingly not the best tools on the market but a good start to basic diagnostics for the home user Regards Pete |
For me its a full control jobbie that im waiting for Mike
Then the cheapest full option is IDS which the actual dealer tool.
http://cgi.ebay.co.uk/FORD-MAZDA-JAGUAR-LA....m14.l1318 Far cheaper than the after market tool available for 7 or 8k Im not related to that ebay advert so i cant speek for the seller, but this is the same as dealer tool interface without the fancy trolly and battery charger etc etc. Regards Pete |
SteveNorman Member Since: 16 Sep 2008 Location: Somerset Posts: 18 ![]() ![]() |
You have to be careful with a lot of IDS interfaces on ebay & the like, as they are chinese clones, which don't function as they should.
Regards Steve |
