Home > Off Topic > LEDS at home
LEDS at home
I have been experimenting with household LED lamps over the last few months, we started with a couple of on-line LED stores but we had problems with the cheap (really cheap) Chinese LEDS and kept having to post them back for replacements.
We noticed IKEA sell LED lamps and bought a couple to try - they are very good. Over the last 2 months we swapped most used lamps to IKEA LED bulbs, the electricity bill arrived today, £25 less .. there is of course a bit of an outlay for the lamps and the adapters (bayonet to European screw-in) but probably less than a year and they will have paid for themselves. 600 lumen lamp = £7 and 6.8 watts, compared to a compact florescent 15w (and take a while to get to full brightness)
I believe the IKEA lamps are made in China but easy enough to return to the local store if they pop
Anyone done anything similar ?
Post #309666 19th Feb 2014 9:16pm
g-mack
ive been using ones from ledhut.co.uk and they seem ok. not sure where they are from. My 109 thread
my youtube channel
Post #309680 19th Feb 2014 9:27pm
What are you using in regular bayonet pendant fittings? Or don't you have those? ___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___[/size]
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #309681 19th Feb 2014 9:28pm
both bayonet pendants, wall lights, table and standard lamps with adapters
Post #309685 19th Feb 2014 9:30pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
We've been swapping all our GU10 lamps (some halogen, some fluorescent ) for LED versions, but used eBay sourced products.
So far they have been excellent over the last 18 months and from memory worked out around £2 per lamp.
It's a bit hard to track the power usage, but our 9 kitchen lights used to consumed 450 watts, now it's 36 watts..! Must be saving something.
Simon
Post #309690 19th Feb 2014 9:35pm
Must look into these myself, these energy saving things are dim as Censored not much good in a house that's dark enough as it is! ___\â­ï¸Lone|Star|State/___
____/🇬🇧🇺🇸\____
Post #309693 19th Feb 2014 9:38pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Colleague at work is gradually replacing all broken bulbs with LEDs. Reckon he's already saving a considerable amount.
I convinced my old man to buy some as well, and we fitted them, the good thing is they are the same glow as old bulbs, but a lot brighter, and not anywhere near as hot, nevermind the saving on them.
Good ones really are the way to go.
There was that rumour that Edison once said "I shall make electricity so cheap only the rich burn candles"... the next goal should be making LEDs so cheap only the rich use filament bulbs... Although as you say, some of the Chinese ones are cheap and nasty. At the moment you still have to pay for good LEDs.
On a similar note, has anyone thought, about using LEDs on the X-Eng - X-Lite? I certainly have Twisted Evil 1998 110 300Tdi White Hard Top
Post #309700 19th Feb 2014 10:03pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I highly recommend LEDs, I bought two of these and I'm very impressed http://www.amazon.co.uk/dp/B0073CY7F2/ref=...71_TE_item
Make sure you go for warm white (at around 2700 to 3000k colour temp).
Pretty much a direct replacement for a 100w bulb, no noticeable differences except it can't be dimmed..
Assuming you pay the normal electricity rate at ~13p per unit and have the lights on for 6 hours a day:
You were spending £127.75 per year, now it should be around: £10.24 Thumbs Up
Post #309704 19th Feb 2014 10:09pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Best of both worlds Rolling with laughter Rolling with laughter
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #309712 19th Feb 2014 10:21pm
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
I have over the last 2 years been changing all the lights in the house for GU10 SMD dimmable units from an electrical company called Ross electrics, i had a few hiccups in the beginning with some brand miss matches in the actual SMD units and the dimmer packs, but for the last year ive been running 30 KOSNIC SMD CREE 5w dimmable units running in different rooms on 4 different 400w dimmers and i think this is the combination i will be sticking with. Thumbs Up
Post #309763 19th Feb 2014 11:45pm
ttuck3r
do you have a photo ?
Post #309814 20th Feb 2014 9:06am
camelman
I've just bought 50 GU10s from cpc (www.cpc.co.uk) at under £4 each Smile
tip, download their 'printed' catalogue from the website and use the product codes in there as they are a bit cheaper than advertised directly on the website!!
At that price, the bulb pays for itself in 1 year if you use it for 2 hrs a day, 6 months at 4hrs a day etc.
Post #309821 20th Feb 2014 9:34am
K9F
Yes I too have replaced 24 GU10s (8 of which were 50w for 3w) all kitchen underlights and exterior floodlights 2 off (from 400w to 6 X 1.5w) and the saving is considerable. Especially visible if you have a gizmo that measures your current consumption you can see the difference physically against your wallet.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #309827 20th Feb 2014 9:46am
SailingTom
Thats Something I intend to do with the outside floodlights as there always going off so seems logical next step, as like others have started on the house with the main lights that are left on. The whole house is getting there but had some problems with cheaper chinese ones with rows of little ones. As the strips keep going out, we have found some better ones now which seem to have no problems plus a nicer yellow light than the harsh white.
Cheers Tom Defender puma dormobile camper
Post #309831 20th Feb 2014 9:51am
camelman
You can also buy LED replacements now for those power hungry halogen floodlights as well. Search for 'R7s LED' on amazon or ebay. they use around 10w instead of 200w.
Post #309834 20th Feb 2014 10:00am
