![]() | Home > Puma (Tdci) > Rear door wiring harness connector |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
Hi,
Does anyone know if it's possible to buy the C2005 connector for the rear door wiring harness? According to the Electrical connector manual it is part number YPC10272. I want to tap of the loom for a couple of modifications and I like to avoid cutting the factory loom. Buying the entire loom would be an option, but I'd like to try this route first. Thanks, Mark http://defender90xs.blogspot.co.uk/ |
Massive thank you Paul for the connector, ideas and advice.
burgenland Member Since: 30 Jan 2014 Location: France Posts: 5 ![]() ![]() ![]() |
hello,
I don't want to open a new topic because I have a concern close to this one. I'm searching with no success the reference of the rear door harness (Right side but not sure there is a difference). I have a central locking and my harness was cut by the door. land rover adjustement - door is not closing well but enough to cut the harness ![]() thanks for your help |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511 ![]() ![]() ![]() |
The door harness for both 2nd-row side doors, is - LR016439
http://www.brit-car.co.uk/product.php/1590...remote_def ![]() . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Super!!! thank you
as fast as lightning |
