Home > Maintenance & Modifications > shock confusion
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
shock confusion
Hi all, im looking at lifting my 90, saying its a minefield would be an understatement, i'm only after a 2 inch lift, what im not sure is whether to go for +5 or +2 shocks, obliviously i will gain more articulation from +5's but will i suffer any more side effects on the road apposed to +2 shocks? also and recommendations on shocks springs and mounts cheers, i do i fair amount of road work and towing . cheers ed
Post #309323 18th Feb 2014 9:16pm
Porny
Site Sponsor
+5" will need different mounts... and spring guides etc etc.
If it was me I would go for a properly spec'd + 2" damper. Which means you can still run standard mounts etc etc.
You have a pm..
Regards
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #309325 18th Feb 2014 9:19pm
landy andy
Gwyn Lewis kit. Simple, strong, well priced, tested, and top kit Thumbs Up Thumbs Up
Andy
Post #309341 18th Feb 2014 9:43pm
