Home > Maintenance & Modifications > Central locking retrofit
grafty99
I am currently undertaking the long and expensive task of turning my basic spec td5 hard top into an xs spec using genuine parts. There are now only three things missing, CDL, heated front screen and a/c. The latter two are in the pipeline but I am currently on the CDL. I have bought the genuine actuators and link rods, but can't find anywhere the connectors that connect to the actuator, and I don't fancy buying a door loom just for the connectors (electric windows already done) they look like mini econoseal type but I'm not sure. Any pointers would be much appreciated Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #308977 17th Feb 2014 10:11pm
PaulMc
The door actuator connectors are Yazaki SSD .050" sealed connectors.
4-way on the driver's door, 2-way on all the others.
The tab size is approximately 1.3mm.
. Paul.
Post #309003 17th Feb 2014 10:53pm
grafty99
Ideal thanks very much Bow down 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #309202 18th Feb 2014 6:07pm
g-mack
im thinking about one of those cheap ebay locking kits! only about 35 quid!! My 109 thread
my youtube channel
Post #309224 18th Feb 2014 7:04pm
grafty99
DONT DO IT!!!!!
Mine lasted a month, lesson learnt, am now going genuine Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #309228 18th Feb 2014 7:13pm
g-mack
ah really? thought it was to good to be true! Sad would the td5 stuff fit a 300 tdi? is it all just wires? or are there ecu's involved? My 109 thread
my youtube channel
Post #309233 18th Feb 2014 7:18pm
PaulMc
You might also have to buy genuine door harnesses, as the Yazaki SSD connectors are difficult to find.
I've managed to get hold of connectors for the electric windows motors, but I'm still looking for the door actuator connectors.
. Paul.
Post #309240 18th Feb 2014 7:25pm
PaulMc
The 10AS alarm unit also controls the central locking on TD5 and Puma Defenders.
The central locking version differs in having an extra double-pole change-over relay on its circuit board.
These are Discovery 300Tdi units, but they illustrate what I'm saying -
Alarm only
Alarm and Central Locking
These relays can be soldered to the circuit board (I have the proper relays and the Thermistor that goes across the contact outputs), or you can solder wires to the circuit board and run them out to external relays, like this -
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #309247 18th Feb 2014 7:38pm
g-mack
mine doesn't even have the alarm! its an early 300 tdi.so zero electric goodies!! i do have an interior light though!! Laughing Laughing Laughing My 109 thread
my youtube channel
Post #309260 18th Feb 2014 8:02pm
grafty99
you could try and match genuine actuators to an aftermarket controller.
alternatively if you wanted to try an aftermarket kit then I have heard good things about these people Thumbs Up
http://www.rclick.co.uk/ 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #309267 18th Feb 2014 8:10pm
grafty99
Not where I got my cheapo kit from I might add Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #309271 18th Feb 2014 8:10pm
g-mack
thats the ones i have been looking at! looks super simple to fit too! My 109 thread
my youtube channel
Post #309274 18th Feb 2014 8:14pm
grafty99
having a quick look through, it looks like they do a battery back up siren, could be a useful addition Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #309276 18th Feb 2014 8:14pm
grafty99
Post #309281 18th Feb 2014 8:16pm
udderlyoffroad
grafty99 wrote:
DONT DO IT!!!!!
What exactly was it that failed though? Like G-Mack, my build is pre-TD5 era, so installing 10AS unit just to get the benefit of a CDL controller seems crazy. I can see the benefit of using genuine actuators and hardware, but for the remote+controller...?
Matt Real trucks don't have spark plugs
Post #309285 18th Feb 2014 8:19pm
