Home > Maintenance & Modifications > What type of Seal / Sealant
hamtheman
Ireland 2004 Defender 90 Td5 SW Java Black
Hi all,
Couldn't find what I was looking for, mainly as I don't know exactly what I am looking for.
I removed all the interior trim panels as I am adding some sound proofing - the I noticed a large thick rust spot on the main body panel between the two side facing seats. It is located just under the window where the window panel and wheel arch panel are joined.
I also noticed that it is bubbling on the outside, but that the seal that should run between the two panels is crooked and alot of water was pooling around it.
So my question is, what seal / sealant should I buy to replace the old with, and is there anything I should bear in mind before doing this? http://mylandy90.blogspot.ie/
Post #308895 17th Feb 2014 5:05pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Hi Ham.
If you do a forum search for "Replacing rear capping" you'll get all of the info you need about this problem from some very knowledgeable members who've had this problem. Thumbs Up
Steve
Post #308913 17th Feb 2014 6:18pm
hamtheman
Thanks Steve -
Just checked and looked at this thread,
http://www.defender2.net/forum/topic22261....ar+capping
Which is great, as I probably will have to do this shortly.
Although I am looking for the correct seal I need for between the window body panel and wheel arch body panel
Thanks again Steve, much appreciated! http://mylandy90.blogspot.ie/
Post #308919 17th Feb 2014 6:34pm
landy andy
I used tiger seal, or sikaflex for joint over the top of the foam gasket to get my 90 watertight, and will be doing the same with my new one. Don't use silicon.
Andy
Post #308958 17th Feb 2014 9:29pm
Mo Murphy
Why not silicone, out of curiousity ?
50 Shades of Pennine Grey
Post #308959 17th Feb 2014 9:32pm
grafty99
tiger seal is much more adhesive than silicone and dries harder - silicone after a while peels off. 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #308961 17th Feb 2014 9:34pm
landy andy
As mentioned silicone is prone to pealing off, it also causes terrible reaction with paint should you need some done later, and tiger seal/sikaflex is actually easier to get a good finish on, and clean up around after the application.
It also has a mat finish, not shiny like silicone, so looks better.
Andy
Post #308964 17th Feb 2014 9:39pm
MartinK
Sikaflex 221 was perfect for mine Thumbs Up
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #308975 17th Feb 2014 10:10pm
VeeTee
Netherlands
Sikaflex or Innotec are good. Defenitely do not use silicone as it contains acetic acid which will attack the metal and increase corrosion.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #308994 17th Feb 2014 10:35pm
hamtheman
Great thanks Andy and everyone else,
Tiger Seal bought, it's not too expensive!!
It's only the second time I heard about Tiger seal, and both were this week. Long story short - I was told about a guy recently rebuilding his 90 and had everything galvanised - the bulkhead he received was warped but he thought he could just push it into place. Turns out he had everything fitted, roof and all were Tiger sealed when he decided the warped bulkhead needed to be fixed. The mechanics had a serious job of removing the freshly sealed panels - a gas heater and a 10 tonne press were used...
So based on that story alone it seems like a pretty solid product - and based on what's said online!
Thanks again Andy - I'll let you know how I get on! http://mylandy90.blogspot.ie/
Post #309023 17th Feb 2014 11:33pm
landy andy
Get some degreaser/cleaner hand wipes,
I use the big wipes
http://www.plumbingsuppliesandfittings.co....13560.html
They will help with the clean up after the sealing, and make sure all is dry before starting Thumbs Up
Andy
Post #309037 17th Feb 2014 11:56pm
gambit
This is just the thing I have been planning to do for a while. Am sure there is a bit of a leak from thisarea, certainly is fromthe seal between the windscreen and bulkhead Sad
Are you planning to loosen the sides from the tub in order to get the sealant in? Haven't got as far as taking off the interior panels yet, so no idea how big a job this is...
Be great to know how you get on,
cheers
Andrew
Post #309087 18th Feb 2014 10:25am
hamtheman
I use the big wipes
Andy
Thanks again Andy - have them bought!
Yeah - I think I'll have to clear the garage first before going anything, or hopefully we get a crazy dry day! Laughing http://mylandy90.blogspot.ie/
Post #309106 18th Feb 2014 12:23pm
hamtheman
cheers
Andrew
Hi Andrew,
Yeah looks like I'll need to loosen the sides from the tub - doesn't look too difficult as theres a few nuts to loosen. The tough part could be removing the original sealant. I'll definitely let you know how I get on - I'll be doing it the weekend after next so March 1st - and then report back here.
I'll also be updating my blog with what happens!
Shocked http://mylandy90.blogspot.ie/
Post #309107 18th Feb 2014 12:26pm
gambit
Hi
That will be brilliant. Look forward to the updates.
Are you also going to do the seal between the windscreen and bulkhead?
Post #309109 18th Feb 2014 12:29pm
