![]() | Home > Technical > Puma Alarm BBUS Siren and Loom |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 ![]() ![]() ![]() |
Been told its the new part number for the siren thanks
The harness and BBUS Siren arrived today just got to mount and fit now on my Puma
![]() Click image to enlarge [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6666 ![]() ![]() ![]() |
Rover
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
I Know! I was shocked to see that. I thought it was dead and buried |
Must be a stock of printed labels they didnt have the heart to throw out and buy new ones
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17780 ![]() ![]() ![]() |
Before you fit it, modify the harness so that you can fit the bbus in a non-standard position which can't be accessed easily.
Exactley what Im doing mate
Can I ask how much it costs? Ballpark'll do. If you go through life with your head in the sand....all people will see is an ar5e!!
The Loom I got from Craddocks it was old stock so got it for old old price £30 + vat now they are £70 + vat the Siren I got from Island 4x4 £102 inclusive you wont find them cheaper than where Ive stated Hopefully Craddocks may still hold old looms in stock ask for John Craddock Jnr he knows whats what the TD5s have the loom all ready in the left wing the Puma pre 2012 dont it was a factory request at new now fitted as standard from 2012 defs The new price to buy outside of where ive said is £200 + I got the lot for Just over £142 Hope this helps
Edit heres the Loom on ebay old stock part number but the same harness i got and part number http://www.ebay.co.uk/itm/Land-Rover-Defen..._739wt_907 |
Harness modified to place siren where the scum wont find it quickly
All fitted and working fine tell me this is the siren supposed to chirp when arming and disarming the alarm the new eec rules say no i think ???????
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
Hi, no idea if they are supposed to "chirp" - just fitted mine and no "chirp" on arming.
I have a question though - the replacement harness has a connector that allows connection of the old sounder as well as the battery back-up sounder. I presume if I have the battery back-up one I don't need the old one as well? Also, the harness came with one additional small black connector ( similar to horn connector) - any idea what this is for? So far I have connected using the new harness: 1) The battery back up sounder 2) Side light 3) Indicator light 4) Front headlight plus main beam connnector (2 here) 5) Two connectors for windscreen wash liquid - front and rear 6) Horn Anything else I am meant to connect and missed? |
extra plug : electric motor for headlight height adjuster
Is that standard for a 110 XS utility or is the electric leveler an extra? I don't think mine has it so I expect its not standard
