![]() | Home > Maintenance & Modifications > Washer nozzle |
| Weston18 Member Since: 20 Oct 2013 Location: Norhamptonshire Posts: 100
I have been told of two ways of doing this job.
One- Told by a LR Tech, Heat up the new one in a bowl of water to remove the end any then place it onto the part stuck on the bulkhead. Apparently its two part. Two- Remove the dash top and do it from there, Its easier with two people as one can hold steady from the outside whilst the other one places the nut on the back of the washer jet, Removing the top of the dash is not as tricky as people make out and can be done in 10-20 mine. Its a frustrating little job though. Cheers |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
always done it by method 1
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
If you've got the time and the inclination it might be an idea to consider this; http://www.defender2.net/forum/topic11649....washer+mod
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435
Thanks for the replies, I managed to get one at the Donington show today for £4 so I'll have a go at fitting it later. Cheers
| ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831
The tip I got from and Inde was to super glue it back together. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to Richard |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
Mine was also broken and I glued it together as it was friday evening before an offroad weekend. And it worked and it is still not replaced. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Mine too kept becoming dislodged on a frequent basis. The base only has a small contact area with the nozzle. To increase the contact area I sealed a flat rubber washer over the base and then subsequently sealed the nozzle back on, it gave a much sturdier foundation for the nozzle itself to be supported on.
