Home > Technical > waste gate
Page 2 of 3 <123>
Caterham
Bl$$dy hell nothing is ever simples !!
On the plus side the engine does seem to be running better (but still too early to draw to a conclusion) however coming home tonight saw worse case ever (and seems to have been getting slowly worse) of clutch slip / judder. Not sure if you know what I mean but its something i've only ever experienced in a diesel. You slowly pull away from stand still but the car / clutch / g box judders big time. A bit like when you wheel spin in a car with crap suspension and it tramps up and down. ?
Aaaaaaaah !
Post #153325 2nd Jul 2012 9:22pm
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
Are you absolutely certain your hand brake isn't sticking.
There were loads of people who had issues with their hand brake binding especially when the engine was hot.
It was often inconsistent, it may be worth backing off the plates from the drum using the adjuster on the outside just to make sure it isn't something as simple as this. Your hand brake will obviously come up higher in the cab but it is worth eliminating this, I suspect.
Post #153564 4th Jul 2012 10:27am
Caterham
I'll have a look and suspect you might be right but only very slightly......
I've noticed a slight juddering when slowing down but it's never bothered me enough to worry about it (compared to rough / smooth engine its really not an issue - however like you say might be worth doing / checking just to eliminate.........)
I just need to do a search now to find out how / where to adjust .....
Post #153566 4th Jul 2012 10:46am
jst
did you get to the bottom of this Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #167309 10th Sep 2012 11:27am
Caterham
NOPE !
bloody ironic - the car is going in for a load of work next week (apart from this issue) and hey presto the car seems to be running well most of the time now. the ONLY thing I can think of is that the last two occasssions I've had to add fuel I've not added a full tank? I normally brim it but not the last two occasions but can't really see how this would make ANY difference.
the dealer ship know I'm not happy so they are gonna have a look into it for me while doing everything else.
I really would love to drive a few other non modified cars cos when mine is running well its exactly how I would expect a modern diesel engine to be and if I'm honest quite quick enough and smooth enough. that said I'd still consider a remap poorly for the improved mpg.
ask me the same question in about 1 month when I get it back. (should be almost a new car by then) Very Happy
Post #167314 10th Sep 2012 12:05pm
jst
Will be interested to see how it develops. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #167319 10th Sep 2012 12:08pm
Caterham
Shocked
blimey - slow down Wayne and you'll be able to post something that other people can read and understand !!
looking at my previous post I can hardly make out what I was trying to say myself so how on earth you lot can is beyond me ! Confused
Post #167341 10th Sep 2012 12:53pm
Caterham
JST......
I believe I've now got to the bottom of this problem.....
the turbo is shot !!
Big Cry and its 3 months out of warranty !! Big Cry Big Cry
Post #307685 13th Feb 2014 8:56am
jst
not good. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #307903 13th Feb 2014 10:19pm
martinfiattech
Just for a try, years ago we used to have a box of tricks called an obd data logger. All you had to do was plug it into the eobd port and take the car for a drive, it would automatically download all avaible ecu parameters on to it so when you got back to the work shop you could up load it to a laptop and view selected parameters in live all be it recoded time so you could rerun your drive and check your read outs you never know you might spot some thing they might have missed or something unique to your driving style that may or may not be causing an issue.
We still use something similar now it gives real time traces via a laptop its great for fuel pressure faults, especially if your apprentice is good at watching a screen.
Post #308184 14th Feb 2014 10:25pm
Caterham
It's in for a new turbo at the moment so once this is completed hopefully there'll be no need to monitor the engine as suggested but sounds good all the same.
Post #309352 18th Feb 2014 10:03pm
Caterham
Suspense is killing me.....
All fixed but I can't get to collect at the moment.
Will update you once I've picked up.
Going back to the wiring loom how do you differentiate between old and newer extended loom for turbine actuator?
Many thanks
Post #311571 25th Feb 2014 7:45pm
Lorryman100
Just look for the new ferrite fuse and new cable ties, electrical tape/shrinkwrap. Thumbs Up
Post #311619 25th Feb 2014 9:23pm
Caterham
Lorryman100.....
I reckon if I have anymore questions I'll simply send them to you as you seem to have all the answers Very Happy
thank you.
and so for my next question;
I don't have my def at the moment to check but I'm 99.9% certain that my wiring is not a per the photos......
shall I be asking for this to be rectified?
def is still at stealers awaiting for me to collect .... assuming I should ask them to fix the loom how should I word it......should this be something they should have done as a recall?
I might break the good news to them tonight via email Very Happy
many thanks.
Post #311630 25th Feb 2014 9:33pm
Lorryman100
You could even send them the bulletin and how to guide as well Thumbs Up
Post #311638 25th Feb 2014 9:41pm
Page 2 of 3 <123>
