Home > Puma (Tdci) > LED Reverse Light not working.
RockfieldWines
Wales 2007 Defender 110 Puma 2.4 DCPU Baltic Blue
Hi Everyone, I wonder if anyone can help Very Happy ?
I just ordered a set of LED lights from MudStuff and have been fitting them as an odd ten minutes allows. So far, the Fog and Stop/Tail lights fitted no problems (inc new plinths for the latter) but the reverse light doesn't work. The conventional filament bulb does work though. I called MudStuff and they very kindly sent me another light next day which they had tested and this doesn't work either...
What am I missing?
Post #307736 13th Feb 2014 12:43pm
I have had similar issues too although the opposite funny enough.
I've never taken the time to work out what it is but power is there for certain, I think generally the idea was that the switch can be funny.
With mine an LED bulb fixture works but incandescent doesn't. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #307739 13th Feb 2014 12:49pm
Try reversing the polarity.
Post #307743 13th Feb 2014 12:58pm
mk1collector
As above swap the wires. I might be way off but I'm sure I heard that filament bulbs can take live and earth into either side but led can only be one way.
Post #307748 13th Feb 2014 1:06pm
Martin
Site Admin
Assuming your new LED fog light works when fitted, take the new fog light off and fit the LED reverse light there instead, does the reverse lamp now work (when you switch the rear fog on)?
If yes, you have a wiring issue to the reverse light connector (possibly pins the wrong way around on the connector).
If no, then the lamp is faulty, but if Mud have tested it then that shouldn't be the case.
Was the lamp supplied with the connector already fitted to the lamp's wires?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #307749 13th Feb 2014 1:11pm
Martin
Site Admin
Instead of the fog you can also test it in the indicator position if that's easier for you to switch on  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #307750 13th Feb 2014 1:12pm
RockfieldWines
Thanks Martin, great idea. Have tested the lamp in the fog position and it works fine so assume it is indeed the polarity. Came with connectors already fitted but I think the old foglight is a replacement following a dink (evidence of re-spray) so maybe wires were mixed up then.
I will try swapping the wires in the connector now.
James
Post #307753 13th Feb 2014 1:28pm
Martin
Site Admin
Hi James,
Yes I would switch the wires in the connector on the Defender, so it is back to "correct" and will work with any lamps present or future without the head scratching Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #307755 13th Feb 2014 1:30pm
RockfieldWines
It works! Thanks so much for the advice.
Now I just have to set up the loading modules on the indicators......
Post #307759 13th Feb 2014 1:36pm
