Home > Puma (Tdci) > Puma central locking poor range fix
Page 1 of 3 123>
ashtrans
Site Sponsor
despite putting a few new batteries in I was shocked at the range of the central locking, approx 1 to 1.5 meters, totally useless,
I came across this :
http://www.aulro.com/afvb/90-110-130-defen...fixed.html
If you take out the front speaker, drivers side, and shine torch up and look towards the firewall you will see a green box, it is about 15 cm long and 8cm tall, with two harnesses attached to the bottom of it. The harness closest to the steering collum has an Orange wire with a light grey stripe, about 15cm long, leading out of it.
You can also see it from the fuse box, below the steering wheel, if you look in the gap on the right hand side.
This wire (orange/light grey stripe) is the Ariel for the remote. I was lucky enough that this wire was close enough to be able to grab it with a pair of long nose pliers from the fuse box (without removing the speaker).
I then soldered a length of wire about a meter or so long, used a stiff piece of plastic strap to poke down in the gap behind the dash and from the bottom of the "A" pillar, a second piece from the right hand side of the steering collum to the fuse box and then just pulled the new wire through, then up the "A" pillar, behind the plastic cover.
Job done - 15 meter remote distance Dave
Post #30481 22nd Apr 2010 4:16pm
K9F
Would't be along the same lines as this then?
AndrewS wrote:
I have had several PM's requesting more info regarding this mod. I am a bit busy this week to provide decent info. I will provide the info this coming weekend pics an all Thumbs Up I dont think I should post the location of the actual box that the wire is fixed too for vehicle security reasons (or am I being over cautious? please discuss). What I will do is pm the location to all those established members that request the info, however if JohnnyThief OnePost requests the info he can go and get fooked.
http://www.defender2.net/forum/topic2149.h...arm+remote
Your link only works if you are a member! Thanks anyway! Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30485 22nd Apr 2010 4:34pm
ashtrans
Site Sponsor
Hi,
I am not sure what the quote you mention is refering to but this central locking range fix has no security implications, it just increases the range on the buttons, Dave
Post #30617 23rd Apr 2010 9:25pm
110SEB
Try pressing the key fob against your temple and you will get up to 15m range all of a sudden!
Post #30618 23rd Apr 2010 9:42pm
K9F
If you've had the misfortune of having had a metal plate fitted to your swede you can get a range of over a mile and a half using 110SEB's principle. I can get mine to unlock in Bournemouth whilst operating the fob on the Isle of White. Honest?????
Rolling with laughter Rolling with laughter Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30627 24th Apr 2010 7:59am
BigWheels
Re: Puma central locking poor range fix
Occurs to me I trashed a fairly new battery recentlythinking it was spent already. About to get a new remote. And its the Deafender's "hearing"..... Sheep Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #30677 25th Apr 2010 2:09pm
Bosun
Thanks for the tip. Worked a treat and only took 20 minutes. Mine works from 10 metres, but hey, that's a whole ten times better. Why couldn't Land Rover have done that!
Thanks again.
Post #32770 22nd May 2010 4:36pm
gonna try this over the next week had to buy a bit of wire though first
Post #36759 22nd Jul 2010 7:16pm
Bosun
Good luck, it realy is a simple fix. Probably too technical for the Defender PD guys at LR.
Just curious, but with a name like konabikes11, are you a keen mountain biker too?
Post #36762 22nd Jul 2010 7:30pm
Used to be i got a Kona Cowan 06 (Electric blue) HT. I have a question when i go to do this mod i know which wire it is and where to route it best but how do you guys think i should join the new wire best? solder then electrical tape or solder and crimp or just crimp? Or does it not really matter just so long as it's connected
Post #36764 22nd Jul 2010 7:36pm
Bosun
Hi, "orange/light grey striped wire" as specified above. I soldered and used heat shink sleeve, but any method that securely joins and insulates the wire will be OK. Routed mine up the 'A' pillar (just two screws to remove the trim) and then just into the roof void. As I said, it works a treat. Plus a few brownie points from Ann, my partner.
Post #36771 22nd Jul 2010 9:03pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Used bullet connectors on mine.
I was told the reason Land Rovers (and Rovers) were like this is to stop people "capturing" the code remotely and cloning it. On the basis you might notice someone with a little black box lurking suspiciously right beside the drivers door Mr. Green
Mind you sort of misses the point of remote central locking MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #36779 22nd Jul 2010 10:42pm
harveyg77
My remote is pressure sensitive. If it does not open froma few feet away I squeeze it harder and swear - gets me in everytime! I do sometimes wonder if the switch contacts are not quite fully closing Wink
Post #36796 23rd Jul 2010 7:55am
done this today just crimped it and electrical tape and also done the same as the pictures of leaving the end slightly bare. A bit fiddily but worked a treat. Thank-you Mr. Green Thumbs Up Mr. Green
Post #36817 23rd Jul 2010 4:35pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
where is the Isle of White???
Neutral
Post #36886 24th Jul 2010 11:31am
Page 1 of 3 123>
