|  | Home > Technical > Wiper 'park' problem |
| Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492      | The spindle that the wiper arms push onto are like a top hat that fits over the wiper machinism spindle and is secured with a small Allen screw if I remember rightly. On mine this had come loose, new ones are a quid or two, either from paddocks or eBay. 2015 RRS Autobiography SDV6
 1994 Def 90 300tdi | ||
|  4th Feb 2014 9:49pm |
| g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967    | my nearside one does the opposite! it parks half way up the windscreen My 109 thread
 my youtube channel | ||
|  4th Feb 2014 10:05pm |
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435      |
 Thanks, I'll have a look at it when I can, but why would both wipers do the same thing if this was the case, surely one wiper would be looser than the other if you know what I mean? | ||
|  4th Feb 2014 10:14pm |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772      | Your wheel box teeth could have gone so when the coil runs past them sometimes they may skip a tooth or two. If you take the wheel boxes out you might be able to turn them 180 degrees to the good side of the gear and refit so no more jumping teeth | ||
|  4th Feb 2014 11:13pm |
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435      | Sorry to rivive an old thread but I've only just got round to looking at this problem, so do you think it could be the wiper wheel boxes that have gone, when the wipers are used there is quite a lot of slack, so sometimes they return to the correct position, sometimes they drop down a bit too much. When they are turned off, I can still move the arms up and down a few inches as though there is not much resistance, I know these are a pain to replace because it'll mean taking the dash to bits, this is the part I suspect have worn, one complete part for each arm....
   Click image to enlarge[/URL][/img] | ||
|  25th Mar 2014 6:42pm |
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435      | Forget the above post, I've been down to take everything to bits and found that the cir-clip had broken inside the wiper mechanism, that made the bush loose etc on the rotating arm, so if I can find a cir-clip that fits I'm done. I thought i'd put a pic just in case somebody has the same problem.
|  25th Mar 2014 9:05pm |
| All times are GMT + 1 Hour | < Previous Topic | Next Topic > |
| Posting Rules
