Home > In Car Electronics > Focal Polyglass 100 CVX
Mac22
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
Can these speakers be used as a direct replacement. Or is there more to it..
Cheers Mac.
Post #304896 3rd Feb 2014 11:54pm
jimbob7
You may have a problem with depth (under the dash??) which can be cured with speaker rings,but if your doing that you may aswell go up a size in speaker,it will help if you tell us what you wanna do with them. Pov.spec,ftw. 2006, 110,TD5.
Post #304903 4th Feb 2014 12:07am
barbel jim
From memory I'm sure I've fitted speakers upto 63mm deep in a puma without issues, without spacers if that helps Thumbs Up
Post #305119 4th Feb 2014 8:26pm
Mac22
Cheers...
Jimbob, hopefully sling the old ones, fit new and turn up the volume.... Thumbs Up
Post #305169 4th Feb 2014 11:09pm
The passenger side is the tighter side iirc, I'd have gone a size up and used rings except I don't like the sticking out look. Prefer it more flush.
Could cut it but it needs to be done carefully so I haven't tried that for now. _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #305194 4th Feb 2014 11:37pm
Mac22
Are you on about the depth or the hole left, if it's the latter the Focals are 100mm
Post #305216 5th Feb 2014 12:53am
10cm is fine then, it's depth that's a little bit of an issue there but I'd say it would be fine. 10cm is a straight swap but larger sized speakers you need to watch the size of the magnet. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #305233 5th Feb 2014 2:06am
Mac22
Cheers.
Now onto the sub..... Mr. Green
If I use a pre-amped unit under seat jobbie, what do I need to hook up to the head unit.
Will I need an ignition live to run it.
Cheers...
Post #305246 5th Feb 2014 8:17am
From the HU there will be a 12v blue wire (likely a wire tail) for turning on the Amp, other than that from the HU you'll need RCA audio cables which carry the audio signal.
So;
Direct battery power feed (appropriately fused near the battery)
Negative shorter than the power feed is recommended to a good chassis earthing point. (Both negative and positive Los need to be the appropriate gauge for the power of the Amp, kits are also availabl.
Some 1mm blue wire at the required length for the remote turn on, approx 1mm dis as it carrys no load, you can fully insulated crimp this to join or solder. What ever you do remember its live and must be insulated.
Then that just leaves the RCA phono cables again at the length required.
For an active sub this is all you need.
Kits are available but get good quality, I built my own up to make sure it is. Quality power cable alone can be £5 - £10 a meter.
I'd recommend Auotleads profoex 8gauge for most active subs power, but please check its suitable for the wattage.
I have 4 gauge Proflex on mine which is larger but would be overkill for what you want, I'd go 8.
Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #305279 5th Feb 2014 1:22pm
Mac22
Cheers Steve...
Post #305446 5th Feb 2014 10:56pm
Mac22
Focal's still not arrive and talking to the eldest, (who has put more amps and speakers in his cars than Motorhead use on stage) recalls he has an underseat Alpine jobbie somewhere.
Finds the sub and off we go..
First hurdle was removing the trim from the HU....hmmmmm. Thought that was going to end in pieces, then dash out and low and behold found the mic lead not plugged in... Whistle
Anyhows well on with it, just 70mph gusts and horizontal rain has stopped play for a bit.
Post #306164 8th Feb 2014 2:07pm
Mac22
All done and not a cable to be seen.... Thumbs Up
Sounds great, can't wait for the new speakers..
Post #306190 8th Feb 2014 3:35pm
Nice job. Thumbs Up I see you went for the Proflex (or at least looks like like it) _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #306204 8th Feb 2014 4:47pm
Mac22
No scrimping there Steve... Whistle
Post #306215 8th Feb 2014 5:29pm
UtilityTruck
Very nice Smile sound good?
Where did you get your front seats from?
Post #306362 8th Feb 2014 10:16pm
