![]() | Home > Maintenance & Modifications > Map reading light |
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 ![]() ![]() ![]() |
Anybody fitted a map reading light and if so which one. Looking at fitting 2 on the trims above the rear passenger doors for the kids to read when away on holiday.
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 751 ![]() ![]() |
I have a hella map light .easy to fit ,robust ...we use them on the response vehicles at work and they take a hammering and last well.
Terry |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
Long arm Hella mounted on the side of the cubby box, fused +ve direct from battery. Would be easy to mount on the rear of box for rear seat use too [taking it as read that it's a CSW USW without bulkhead]. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
I fitted a RRC auto dipping mirror, it has 2 map lights built in
![]() the same as this one on ebay ![]() |
I have the Outback roof console with map LED spot lights Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
Maybe a bit pricey being an LED one but I use one of these...
http://www.carbuildersolutions.com/uk/hard-wired-map-light Used one last year to do the BAMA Salisbury Plain night navigation competition and it did the job nicely, being able to use it in red mode as well as white meant that I could read the map with it and still be able to see outside when I needed to and I suspect it also meant less reflected glare for the driver. The switch is perhaps a little fiddly but OK when you get used to it. Fitted the same one to Pam's 90 after the Salisbury plain event. Being an LED the current draw is tiny so no problem if it gets left on. http://www.yorkshireoffroadclub.net/ Last edited by davew on 3rd Feb 2014 1:37pm. Edited 1 time in total |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
The OSRAM units are nice...
http://www.mobilecentre.co.uk/index.php?ma...eyword=map Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
good idea!! My 109 thread my youtube channel |
pretty easy to fit,, un-snap the defender mirror, 3 screws, the mirror is simply screwed on
![]() electrical feeds taken from interior light. |
Any pics of it fitted please?
