![]() | Home > Tdi > Strange phenomenon... but much worse when wet |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
I get a similar thing on my 300! Mine happens when I'm coming to a standstill and I dip the clutch. Start getting a knocking. Sounds like my golf when DMF let go!
Thing is my 300 has recently had clutch hd fork etc etc done! My 109 thread my youtube channel |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
It sound like the problem I had with my 300. It turned out to be the rear stub axels were shot, one locked solid that's the only reason I found out what the banging was. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
better check my stubs then! what exactly was the problem with them? My 109 thread
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 97 ![]() ![]() ![]() |
How about checking the hand brake, shoes locking onto drum and the cable has started to fray and not releasing fully. This was the problem my boy had on his 90.
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 829 ![]() ![]() ![]() |
What he said........ My guess is hand brake sticking on,
Very very common problem, oil seal goes and allows oil into Drum which over time turns to a lovely goooooiey grease That causes shoes to stick to drum. Have fun be happy |
hmm good call, i really need some decent weather, as my jobs are mounting up! My 109 thread
Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280 ![]() ![]() |
hmm.. handbrake could be an issue, it feels like it is coming from immediately under the seats, so that would be about right for handbrake.
Will need to have a look. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2769 ![]() ![]() |
Check the engine/gearbox mounts too while you're under there.
