Home > In Car Electronics > Alpine Head Unit.
Mac22
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
Alpine Head Unit.
Hi..
I have finally paired my iPhone 4s to the head unit everything works except the caller can't hear me.
it's ticked on the phone to the correct option.
Any ideas
Cheers Mac...
Post #303505 30th Jan 2014 8:18pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
You didn't install the mic near an air vent or anything did you? 1998 110 300Tdi White Hard Top
Post #303513 30th Jan 2014 8:42pm
Mac22
Nope, it was stuck on the steering column...
Post #303540 30th Jan 2014 9:08pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
On my 13 I always find when someone rings me , I have to select it on the phone before they can hear me.
Dialling out auto picks up
Post #303549 30th Jan 2014 9:22pm
I have my mic at the top of the a pillar on the drivers side. But it is Kenwood so actually works! (Takes cover!)
It seems iPhones and most in car BT system often get sone issue or other at some point.
Most are easily solved though with a simple fiddle of a few settings.
Might be worth doing a sound check though, give someone a call as a test if they are willing.
Ignition on no air vents going so silence, see how it sounds then.
If it still sounds quiet there's a mic sound pick up issue, if it sounds better it's the positioning that's causing the problem.
If none of that works out then there is small chance there might actually be a problem with the mic it's self. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #303573 30th Jan 2014 9:51pm
Mac22
Tried it again and I was shouting that loud they could hear me in the house...Who needs a mic... Whistle
Post #303589 30th Jan 2014 10:21pm
Mac22
Spent an hour this morning with the instructions and still can't get the mic to work...
Has anyone got any ideas..
Cheers...
Post #304487 2nd Feb 2014 7:52pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Pull the head unit out of the dash and make sure the mic is physically plugged into the back of the head unit.
Post #304509 2nd Feb 2014 8:38pm
Mac22
It was close to getting pulled out and slung across the carpark... Whistle.....Have anther go tomorrow..
Post #304574 2nd Feb 2014 11:14pm
borderterrier
Dont do that, its a cracking stereo. Shocked Has it ever worked, or has the mic failed recently? Its just a 3.5mm jack plug in the back, so it may well of come out.
Post #304588 2nd Feb 2014 11:58pm
bell-auto-services
If its an incoming call not outgoing that has the problems, have you tried to answer the incoming on the head unit its self and not on the phone ?
In sone cases if you answer from the phone and not the head unit the mike used is the phone mike and not the external one, which means while in the call in some cars you have to manually select the car before the caller can here you.
I think this is aimed at you not having or supposed to touch your phone while driving and so control is done via the head unit and not the phone buttons.
Pete
Last edited by bell-auto-services on 3rd Feb 2014 12:33am. Edited 2 times in total
Post #304598 3rd Feb 2014 12:27am
AndrewS
Yep my phone give me this option, answer the call on the phone and you have use the phone for the call. Answer the call with the head unit and the Bluetooth takes the call.
Post #304599 3rd Feb 2014 12:32am
Mac22
Incoming and outgoing, the mic wont work. Adjusted the gain on the mic and bounced between phone / speaker / HU while on a call. Pha!!! I'll see if it's not been plugged in...
Post #304601 3rd Feb 2014 12:41am
